jinman
Rest in Peace
- Joined
- Feb 23, 2001
- Messages
- 21,059
- Location
- Texas - Wise County - Sunset
- Tractor
- NHTC45D, NH LB75B, Ford Jubilee
Not sure if I can get one that beefy around here, I will try and find something comparable. Thanks!!
How deep can you go at a swipe? Guess it depends on soil, I have mainly older grass pasture.
If you have a Tractor Supply were you are, you can get the KK tiller. They normally have lots of them in stock this time of year.
As to the question of how deep you can till, it certainly depends on your soil as you mentioned. In my case, I used a two-bottom plow to break up the native soil before using my tiller. However, with multiple passes, I think I could have had my soil tilled to 6-8 in. deep. In the attached photos, you can see where the axle of the tiller blades mount on the right side of the tiller and also see that it is not visible when tilling. That means it must be at least 8" deep to the bottom of the tines. You can see from the other pictures that I tilled deep. My soil was well aerated and very fluffy when I finished. There is an adjustment to the depth of the foot on each side of the tiller. On firm soil, that will control how deep you can till, but when the soil is tilled, the feet just bury up in the soil instead of gliding on top of firm ground.
The hydraulic cylinders you see in my photos do not provide any downforce. They simply provide toplink and sidelink length adjustments. The 3PH does not have any downforce except for the weight of the implement. In the case of the 72" KKII tiller, that's about 700 lb. You won't need more downforce other than that.
