Why is that better? Since 90% of engine wear is done in the first few seconds of startup,I'd rather have higher viscosity residue in the motor when I turn the key.Synthetics last longer, but I think that oil should be changed long before the increased lifespan comes into effect - especially in a diesel. 50 hours and my oil is black as soot - I change it to get the debris out.
Your thinking is wrong and i'll tell you why, as you said
"engine wear is done in the first few seconds of startup" and you are 110% correct on that but what you fail to see or understand is a lighter viscosity oil say a "5w,0w" etc, will flow and get to them critical wear spots
faster then your 15w40 thicker visc base oil will thats why in most cases a manufacture these days recommend a lighter oil for winter use. Summer warmer temps really isn't too much of a issue but when it gets cool to cold out a thinner multi is the way to go, start up's will be 100% better also, Not saying a 15w40 is bad, far from it it works very well just pointing out that it's not a one oil fits all type of thing for every application.
say you put 15w40 in a pull start 6500w generator no problem in the summer but try starting that unit in the cold winter,good luck.
in other words viscosity is the oil's
resistance to flow or motion. Viscosity varies under different temperatures and is important for maintaining a lubricant film between moving parts. Viscosity plays a role in an engine's cold-cranking ability also, the movement of gears, load capacities all have a part in it.
and changing your oil at 50hrs is crazy that oil upon analysis would show you it's far from being depleted,i could show you multiple UOA's showing 200,250,300hrs and the oil is still fit for use,TBN,wear metals,insolubles all with in universal averages why? because usually a HDEO will have more detergent(dispersing/cleaning agent),anti wear adds(for increased wear protection) and also have the ability in holding formed sludge,soot,dirt particles in suspension and thus allowing your filter to clean more efficiently.
but the end result is you,,you decide what's best for your equipment and go with it :thumbsup:
