round baler
/ round baler #1
wilbur51
We have a small farm on which we raise cattle. Currently I have a 504C round baler which I pull with a 31HP Kabota. The baler works good but it is hard to start a bale and it seems I'm always on the edge of something going wrong. So I'm looking to upgrade, so far I have looked at a 1993 New Holland 640 which appears to be in great shape but I'm not sure if the Kabota could power it? Also found a Hesston 550 which also looks to be in great shape but I know little or nothing about them other than it makes a smaller bale and looks as though my tractor could pull it. Currently I bale about 100 bales per year, eventually I hope to bale upwards of 400 round bales per year. Any insights or suggestions?
/ round baler #2
I own a 1998 New Holland 640 round baler. It has been a great baler. I service each grease & oil points daily, and have had no operational problems with mine. The only problem I ever encountered was a few jams at the pickup which was caused by trying to pick up too much hay at one time. I am sure this is true for most balers. I highly recommned the NH 640. I would check with your local NH dealer to determine if you tractor has sufficient HP to operate the 640.
/ round baler
Thanks for the information, I will call the dealer and find out if 30hp is enough tractor. Do you suppose there is much difference between a 1998 and a 1993? How does yours tie the bale?
/ round baler #6
I have a New Holland 644 and I bale with JD 5325 and I have no problems, 55hp at pto.
CASE INTERNATIONAL 3900 DISC HARROW (A63291)
CASE INTERNATIONAL...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
Blue Diamond Brush Cutter (A64047)
Blue Diamond Brush...
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
2022 Coyote Renegade Trailer (A63116)
2022 Coyote...
2019 ALLMAND LIGHT PLANT (A63569)
2019 ALLMAND LIGHT...
