RTV900 cracked transmission?????????????
   / RTV900 cracked transmission????????????? #11
Darin,
If the dealer considers this OK, request something be put in writing that if it should crack/fail beyond the 1 year warrantee that he'll take care of it.
   / RTV900 cracked transmission????????????? #12
yes get it in writing for later date of it gets worse. Its hard to tell from the photo but it sure looks like a crack.
FRank
   / RTV900 cracked transmission????????????? #13
Good luck getting a dealer to sign off in writing for something like that. I would think your best bet would be to have the dealer contact Kubota directly and get something in writing from them instead. Otherwise, if Kubota doesn't cover you then I would force the issue with your dealer to replace. You better believe that once your outside of that warrantee and IF this crack gets any worse then your S.O.L. for sure. /forums/images/graemlins/mad.gif
   / RTV900 cracked transmission????????????? #14
I seriously doubt this crack will cause a problem...it is far more likely an artifact of aluminum casting. It appears to be on the top side of the T/M, so it is highly unlikely to form a leak any ways given the location and T/M case fluid level. There is no recall and I have never heard or seen something like this cause a problem.
   / RTV900 cracked transmission????????????? #15
<font color="blue"> it is far more likely an artifact of aluminum casting </font>
That is what it is. I have seen that type of cosmetic defect in many, many castings.
   / RTV900 cracked transmission????????????? #16
I agree. /forums/images/graemlins/cool.gif
Bobcat Sweeper/Bucket  72"  (A52384)
Bobcat...
UNUSED SWICT 72" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 72"...
2017 UTILITY 102" X 53' VAN TRAILER (A51247)
2017 UTILITY 102"...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
