RTV900 Hydraulic Angle Kit
   / RTV900 Hydraulic Angle Kit #21
I have a kit on order. Checked on it yesterday. Was told on order and the snow will be over for the year before I get the kit. Guess I will have all summer to install it. Dealer has 6 0n order and so far 1 came in. He said mine is next but still thinks it will be a month or so.
   / RTV900 Hydraulic Angle Kit #22
I too have one on order.. as well as th esecond windshield wiper and rear work lights.
Frank
Frank,
Do you know what the difference is between the driver's and passenger's wiper kit? I assume it would be in the wiring.
Last year, when there was only one wiper kit available, it had the Kubota sales #V4215 and I assume everyone would put in on the driver's side.
This year they're offering two kits - one for the driver's side, #V4267, and one for the passenger's side, #V4215. So last year's driver's kit is now this year's passenger's kit. Did you order a passenger's kit or a driver's kit and will you have to move the existing driver's wiper to the passenger's side?
   / RTV900 Hydraulic Angle Kit #24
I had one of my enployees who was near the kubota dealer order it. Im gessing it was for the passenger side?? Ill have to go look as its down the garage..
Ill let you know..
Frank
   / RTV900 Hydraulic Angle Kit #25
just looked the passenger side wiper is NOT the same as the drivers side.. Its shorter. Due to the fact that the passenger side swings towards the drivers side wiper but cannot hit. So they made it shorter.
Frank
   / RTV900 Hydraulic Angle Kit #26
I installed the angle kit today. Took 2 hours. No problems at all. Simple hook up. works great. Snow will be here soon to see how it works.
The hydraulic angle kit really helps. Especially if you have a cab and heater. Before the angle kit I would loose the cab heat every time I opened the door to go outside to manually change the plow angle. Now I can sit inside, stay warm and keep my feet dry.
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
UNUSED X-STAR 20' LOADING RAMP (A58375)
UNUSED X-STAR 20'...
UNUSED WHITETAIL DEERE BUCK AR500 3/8" STEEL (A58376)
UNUSED WHITETAIL...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59575)
2018 FREIGHTLINER...
1964 Mercedes-Benz 190D Car Sedan (A56859)
1964 Mercedes-Benz...
Pines 1400 Tubing Pipe Structural Bender (A59213)
Pines 1400 Tubing...
