scgargoyle
- Joined
- Dec 18, 2007
- Messages
- 364
tvfool.com is a good site to guesstimate reception.
UHF is pretty much line of sight, and thanks to the curvature of the Earth, 60 miles is about the limit even if the terrain is dead flat. VHF is slightly more forgiving, but even there 100 miles is about the limit. I once lived at Eola Crest in Oregon, and with Radio Shack's best antenna, mast mount amp and a rotator I could pick up VHF signals from Olympia to Medford, but that was from the top of the highest hill around. I also got an amazing number of FM stations. There are still a few digital stations broadcasting VHF, but half the VHF band was reassigned to emergency communication.
Where I live now is very similar to you. Not only do we not get television, we only get 3 radio stations and no cell service. The satellite is great, and Dish includes both Sirius radio and a bunch of CD channels. I have DSL, but it's too slow to stream video. Satellite is worth the money.
Unless you can move the antenna to the top of the "hills on both sides", you're destined for satellite. There are some free satellite services - look up "free to air". Otherwise, give DirecTV a call and be happy.
Mike
You are being told the truth. The size of the dish restricts signal strength and the Ku band transit signal is attenuated by rain. The reason cable systems don't go down is they generally run a 4.5 meter or larger antenna. The only way to reduce the occurrences is by installing larger diameter dish 1.2, 1.8 or 2.8 meter and this depends on your mount strength, obtaining a lower noise figure LNB or a combination of the 2.Thanks for the advice. The disk is located right next to our deck. When snow accumulation occurs, I do reach over with the broom and sweep it off. But when there is a heavy severe rain storm, we lose our signal quite often. The signal comes and goes at times and if the thunderstorm is really severe, we don't regain a signal or reception until the storm passes. Any possible suggestions would be appreciated. We have called the 1-800 number several times and they insist that this is the norm. Our Son has Downs and if the reception is delayed for extended periods, he gets despondent when he misses his shows.
