Rust getting bad all over my Kubota
   / Rust getting bad all over my Kubota #111
I can't say if it was powder coated or not but if you look at your step the orange will quickly wear and you'll see a white primer under it. It's quite possible that the primer was also a powder coat.
My step isn't orange it's grey and yes it's not powder coated. On my tractor it's just the orange that's powder coated. Did I mention I hate powder coating :mad: :laughing:
   / Rust getting bad all over my Kubota #112
Possibly some tractors were made with inferior technology when powder coating was first developed. As for me, I would never buy a tractor that wasn't powder coated withing the last 10 years. Here is why.
I bought 3 or 4 JD garden tractors in the 1980s, I believe, that I know were spray painted with the latest technology that the factory had. The last spray painted mower deck and tractor and the rest of the attachments rusted up all the time. It got to the point where I would sand down big parts of them and grab the spray can and put more oil based paint on.
I finally got a powder coated garden tractor in the 1990s I believe and never had to touch the paint unless I scraped or wore through from rubbing on something. But generally it would be just the exact spot where the rub was or it was chipped from gravel or something. Nothing else would have to be touched and stilled looked great. Some of those tillers and snowblowers I still have, but I know from my experience if it was spray painted it would never have held up like that.
I could be maybe you had a bad powder coat job, or I had a bunch of spray paint jobs from the factory. :eek:
   / Rust getting bad all over my Kubota #113
That's kind of odd. I wonder why Kubota would make the open stations Orange and the cabbed tractors Gray? I can confirm that the orange step has primer under it (along with the floorboard).
When it comes to powder coating I don't see how it can get into seams between layers of metal like liquid paint can. It's advantage is the ease at which it can be painted and the fact that liquid paint can run. The EPA loves it because it doesn't use solvents to thin it out.
   / Rust getting bad all over my Kubota #115
Could it be possible that the seamed edges only get a dusting of powder coat, due to the fact that if it got sprayed on heavy it would crack upon assembly with air tools, and really bring out alot of complaints, the newer paints on the other hand are alot more flexible. So paint will wear quicker than powder coating, but your seams would hold up better. May be a toss up, not sure, but just thinking.
   / Rust getting bad all over my Kubota #116
Factories may be different but John Deere takes the super clean frame or whatever it is and puts them on a trolley and immerses the parts by running them through a huge tank full of primer. This I think is the undercoat, and then it bakes on at 400 deg. for a half hour or so, then it goes through a powder paint booth where paint guns put a layer of powder that attaches to the part and sticks on because of the electrical charge to the part, then it is baked on again. The powder paint doesn't get into the nooks and crannies. It is the undercoat that keeps it from rusting. As far as I know.
   / Rust getting bad all over my Kubota #117
Yup. Throwaway society. I've been a bodyman for 45 yrs now. $50,000 trucks come in, 3 yrs old, with large pieces of rocker panel missing, holes in cab corners and doors. We now have design engineers who've never owned a truck buft this is what the "computer" says to do. Da! Panels and seams are no longer caulked nor are they rustproofed. Even a sealed seam will eventually rust. Especially a lap seam where metal is twice as thick. Sun will shime on the top surface while the underside is shaded. Difference in temperatures will cause condensation between the two layers. Rust will form inside, bubble, and even push the caulking out of the seam. Everything's being made cheaper and cheaper and quicker. Planned obsolesence by the industry to assure we buy a "new" one. No pride in quality today. Just get that almighty buck. "First in initial quality!" That means "new", right? How about 6 months, a year, later? We mention the older ones being good. What's the difference between then and now? "Heavier metal." "Pride in craftsmanship." Here's reality, think about it. The high cost of union demands has forced the industry to "cheapen" their product. Unions are cutting their own throats. Quality drops, sales fall off, industry closes. No jobs. Union or otherwise. We can't stop rust. Been trying to do it for 45 years. Sad but true.
   / Rust getting bad all over my Kubota #118
when I was looking for my used f350 drw, I went to see lots of low mile trucks that were only a few ys old.. and many had extensively rusted out undercarriages and frame areas around body panels. if it went up north around salt.. it was a bum deal.
they should factory undercoat anything that is north of a certain line.. ;)
   / Rust getting bad all over my Kubota #119
When I was looking for a truck in 09 I started looking at used trucks. Two of the trucks I got serious about were from Michigan per the car fax. Both trucks had been bought by different dealers at auctions. I told the dealer there was no way I would buy a truck from the rust belt. I ended up buying new. I have a 93 model truck that I bought new that has zero rust. It would break my heart to watch a good truck crumble from road salt.
   / Rust getting bad all over my Kubota #120
No matter what item i make in my shop i have it powder coated. I have NEVER had a finish fail. I truly believe its all in the prep. My guy sand blasts it just prior to the trip to the oven.
I personally LOVE powdercoat finishes.
2007 TEREX ADVANCE FD3000 FRONT DISCHARGE AWD MIXER (A59575)
2007 TEREX ADVANCE...
Adams 16T Tender Body (A56436)
Adams 16T Tender...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
Pallet of 10 Chains and 5 Binders (A57453)
Pallet of 10...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
1992 Ford L9000 Cab Chassis with Low Mileage Cummins (A56436)
1992 Ford L9000...
