Rust Penetrant Recomendations
   / Rust Penetrant Recomendations #41
Went to the Ford dealer to try and get the proper stainless studs as per TSB 05-5-4. The dealership didnt even know that the proper repair is to replace the steel studs with stainless so of course they didnt have them in stock:rolleyes:. Whats more concerning was the parts guy told me they just repaired a 5.4l the previous day and used the original steel studs. That guy will have the same problem in a couple years. Will the dealership go good for the re-repair? Doubt it...
I disagree. Toyota used to have stock stainless studs in the exhaust flange. They worked great for a long time, but then the heat got to them and they broke, just like a steel stud. Problem is, you can't drill stainless half as easy as steel. Straight steel will fail, but it is easy to replace. The stainless fails in about the same amount of time, but it awful to work with. My opinion.
   / Rust Penetrant Recomendations #42
I have to remove the exhaust manifolds on a 2003 F150 to repair an annoying exhaust leak for inspection,and the manifold studs are extremely rusted:mad:. This has me thinking about rust penetrants.:D
What rust penetrants do you recommend in general?
Ive had the best results with Aerokroil however i no longer have access to it and ordering a case by mail order from Canada is $$$:eek:. Not to mention the delivery time involved.
Ive tried Liquid Wrench, WD 40, Lloyds and the Bowmans and the like, but havent had much luck so im open to suggestions.
Can anybody recommend Zep's 45 or Twister?
On a related note, do any members here know where AeroKroil can be bought by the can in Nova Scotia?
Does anybody know of a head to head scientific test done that tested penetrant effectiveness?
Good luck on the project.
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
Bobcat T590 (A53317)
2025 Swict 84in Bucket Skid Steer Attachment (A56860)
2025 Swict 84in...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
