S-370D Front differential knuckle housing
   / S-370D Front differential knuckle housing #11
You get it fixed yet ?
   / S-370D Front differential knuckle housing #12
I have the luxury of having a tractor that doesnt run at the moment. Im waiting on an oil ring which should come today and everything can go back on. If you want to see my trials and tribulations heres the link.
http://www.tractorbynet.com/forums/mitsubishi-satoh/392553-77-satoh-beaver-s370d-wont.html
Im on dad duty today and my little helpers are more like saboteurs so I dont get to have tractor time until nap time. Ill double check my front bearings this weekend, my first priority is cycling hydraulics and flushing all the crap out of the lines. Ill run it around the homestead in 2wd so I dont cause any damage before the inspection. Do you have any pictures of your teardown and replacement? Where did you find new bearings?
I ordered the bearing from Valley Power
I work in Alaska so parts should have arrived by time I get back home.
Teardown is pretty straight forward. You can remove bearing without taking wheel gearbox off but I did so I could clean out all the old grease.
202476 (A54757)
202476 (A54757)
2011 Kenworth T800 Water Truck (A54865)
2011 Kenworth T800...
Galvanized steel fence (A53424)
Galvanized steel...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
