s150 hydraulic leak
   / s150 hydraulic leak #1
gwilkrrs
bobcat 763 and s150
machine has around 1500 hrs on it. after using a grapple bucket a bit i noticed fluid coming from the front right foot hole area in front of machine. after searching i found the control valve assembly on right side and noticed a drip from the bolt head under the solenoid so i took it out but all the o rings look good? now i am wondering if the solenoid above is leaking?
   / s150 hydraulic leak #2
Wrap a rag around the solenoid, run it awhile. Look for oil on the rag.
so i pulled the solenoid yesterday to check since i had stuff ulled off anyway.
the 2 smaller o rings on the shaft are good, the big o ring is hard and chipped/nicked and the outside o ring in the recess is loose fitting and nicked.
hopefully dealer has them in stock and they aren't terrible......
i think this is it.
what really shocked me was that none of the treads had any teflon tape or pipe dope on them and only relied on the o rings.....
   / s150 hydraulic leak #5
got it- thanks.
now to find the new o rings-
i can only find a whole new stem but not replacement seals....
   / s150 hydraulic leak #7
any hydraulic shop, bearing supply can find O rings, we have a local bearing supplier that has found us some odd seals over the years, check the local supply guys out
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A56857)
2017 Kawasaki Mule...
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
2017 Ford F-550 Cab and Chassis (A56858)
2017 Ford F-550...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
CHAINSAW BENCH GRINDER (A58374)
CHAINSAW BENCH...
