Safe way to work under loader.
   / Safe way to work under loader. #31
I've worked around heavy equipment most of my life and I can verify for you that hydraulic failures can and do happen that way. When a catastrophic failure happens, you won't know about it until it is on the ground. I have seen it happen many times.
Yea right. I have blown many a hydraulic line. How much weight will also dictate the rate of fall. I am not climbing under my bush hog or my 30' wide disk. But a new empty loader on my 5075E to blow the coolers and service the air filter? Not going to worry about that one.
   / Safe way to work under loader. #32
If you want to do that , it's fine with me. I'm not going to try to stop you. I'm not going to debate it with you either. So go ahead and do it, it's a great way to "thin the herd".
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53473)
2019 New Holland...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2010 John Deere LA105 36in Riding Mower (A51694)
2010 John Deere...
2014 Freightliner M2 106 Medium Duty Passenger Bus (A51692)
2014 Freightliner...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
