Safety interlocks on BX24
   / Safety interlocks on BX24 #1
easternhunter
Charleston, WV
Kubota BX24
OK guys ... My apologies for the late and urgent request ... am chastened by having to ask!
I have what I think is a safety interlock switch not allowing my BX24 to start. Everything seems to work ... fuel pump ticks, glow plug shows working ... but will not spin the starter.
Have seen this before. Requires jiggling controls for such things as gear speed selector around until something changes and it starts.
Need the tractor to move snow ... way too much driveway to do by hand.
What do I need to know to start isolating the problem?
   / Safety interlocks on BX24 #2
I would look first at the forward-reverse pedal switch. I don't know how it works or where it is. Just that if you are off the running tractor and move the pedal, it dies.
Bruce
   / Safety interlocks on BX24 #3
PTO switch /lever must be in neutral, HST pedal must be in neutral position also some tractors require the transmission to be in neutral also. Check all these and if all are in neutral, then rock the HST pedal back and forth while holding the key in start position.
   / Safety interlocks on BX24 #4
Try rocking the HST pedal back and forth. If that doesn't work turn the key on and try jumping across the starter.
Thanks guys. Read the threads on non-starting BXs. I suspect the PTO ... will try it but now have to dig the tractor out first.
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2004 JOHN DEERE 650H LGP CRAWLER DOZER (A60429)
2004 JOHN DEERE...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2018 CATERPILLAR...
2022 CATERPILLAR D6XE LGP HIGH TRACK CRAWLER DOZER (A60429)
2022 CATERPILLAR...
2019 Deere 35G (A53317)
2019 Deere 35G...
