Sagging Sofa
   / Sagging Sofa #11
I'd try the plywood trick, first. See if it is acceptable. If not, use the plywood to build a box to hold all the pieces you take off when trying to reupholster it! /forums/images/graemlins/grin.gif
   / Sagging Sofa #12
   / Sagging Sofa #13
Hi Mike,
The guys have given you some good advice here! As someone else pointed out, you really wont know what kind of shape the frame is in until you start removing the upolstery. Meaning, how are all the glues joints in the frame, any wooden supports cracked etc. If you were going to go through the trouble of tearing the whole sofa down, you could also inspect the springs as someone else pointed out. To rebuild the sofa properly, all that needs to be done.
If your lookin for the quick fix, I would try RobS suggestion and use the brown masonite trick, and you could also add a wooden block under the middle section especially if the frame has been undermined for extra support.
Im by no means an expert, but I have built my fair share of furniture, and at one time I did build some wooden frames destined to be upholstered furniture. I can tell you this, unless it started its life as an upscale expensive sofa, the frame is not much to look at !!!
Good luck.
   / Sagging Sofa #14
Hi Mike,
Good luck.
   / Sagging Sofa #15
certainly not my area of expertise -- but could you turn it over, rip off the bottom dust cover, and maybe see what's going on that way?
   / Sagging Sofa #16
   / Sagging Sofa #17
</font><font color="blue" class="small">( certainly not my area of expertise -- but could you turn it over, rip off the bottom dust cover, and maybe see what's going on that way? )</font>
My thoughts, exactly. /forums/images/graemlins/smile.gif ...and you get to keep any spare change you find. /forums/images/graemlins/wink.gif
   / Sagging Sofa #18
   / Sagging Sofa #19
I've done the wood board trick before.
I'd get a board as long as the seat area ont he couch, and make it a 1" thick, by as wide as you can get, depending on the sofa setting space... .. for instance... a 1"x12"x6' might do a narrow love seat.. etc... wider the board the better.. and it won't flex as much as plywood!
Soundguy
   / Sagging Sofa #20
Soundguy
2014 Infiniti QX60 SUV (A53424)
2014 Infiniti QX60...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2005 CATERPILLAR 740 - 6X6 OFF ROAD WATER TRUCK (A52706)
2005 CATERPILLAR...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55218)
Galvanized...
2003 John Deere 310SG (A47477)
2003 John Deere...
