Oil & Fuel Satoh 630 D - fuel problem
   / Satoh 630 D - fuel problem #1
LarryP
I was driving my Satoh 630 Diesel and it just quit. I pulled the fuel lines off, at the top of the block, and turned over the tractor and no fuel squirted out. Next I removed the injector pump, which looked fine, and then looked inside the engine block and all parts were turning.
Any suggestion?
   / Satoh 630 D - fuel problem #2
Did you try opening the bleed screws? If there is no fuel there your filter may be stopped up. Don't take the lines loose from the injectors until you know you have fuel going to the pump, bad for the pump turning it with no fuel in it.
2019 FORD F-150 XL CREW CAB TRUCK (A59823)
2019 FORD F-150 XL...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
Mower deck storage axles
Mower deck storage...
1996 International Water Truck with a Caterpillar Engine (A61306)
1996 International...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
