Satoh 650G dilemma
   / Satoh 650G dilemma
I had the radiator re-cored, but still getting light on the dash for water temperature warning.
Could this be caused by the sending unit? Possibly bad? Just to make sure I have the right one, is it located just under the carb, on the right side of the engine? There are water lines coming from the water pump that seems to go into this part, and I assume that this is the sending unit, is this right?
Ok. Need a few points of clarification.
1. What thermostat should be in the engine? 180?
2. Are there different sending units? Anyone have a part #?
3. Are there two hydraulic filling caps; one under the seat, and one by the gear shift?
   / Satoh 650G dilemma #13
The thermostat part# NAPA 323-180.
Don't have a sending unit #.
The hydraulic oil (JD 303 or equal) is filled under the seat but the cap by the gear shift is for gear oil (80w-90) in the transmission. Fill level is determined by a plastic cap on the left side of the tranny by the foot rest.
   / Satoh 650G dilemma #14
Does anyone know the radiator cap pressure rating for this tractor? Mine is now in multiple pieces. It still holds pressure, but I would like to replace it before it doesn't!
Robert
So, if I understand you correctly, I should drain the hydraulic/tranny universal fluid from the case, refill with 80-90 gear oil, until it starts to come out of the plug hole on the left side by the foot rest? Then add a tad more to top the ole girl off.
Sorry for the extra reply (see above), but if anyone know the Napa part for the temp sensor/sending unit, it would be greatly appreciated. I confirmed that mine is bad, since when I start the tractor cold, if flickers on the tach on and off. I'm going to replace, but can't find the proper exchange part #.
I'm heading to advanced auto, and auto zone with the used part and see if they can match it up. Hopefully, someone will give me a part # before then.
Thanks in advance. This is a very helpful forum. One of the best.
ok. Re-cored the radiator, replaced the temp sending unit, and my light is still coming on. I'm not a smart man, but if there is a 180 degree thermostat in the tractor, and the standard temp sensor is a 180 degree sensor, wouldn't the light stay on? Something's not making sense with this logic.
I saw on NAPA part site, that there are two thermostat's for that engine: a 160 and a 180. I would assume that the thermostat should be slightly lower temp than what the sensor is rated at. Unless there some other logic behind it.
any insight? Am I making sense?
   / Satoh 650G dilemma #18
does the light ever go off? is the sender switch working ? is there flow in the radiator? is the engine running too lean?
The light flickered before replacing the sending unit. If I pull the wire of the sending unit, it goes out completely, and doesn't come back on. So it appears there is not a short in the wire.
I cannot see into the radiator to see if there is flow. I did test the water pump by taking off the top hose and there was definitely water flow.
Is it possible that there is something clogged in the engine block? Is there anyway to test this? Or is it highly unlikely that's an issue?
One thing worth noting is that when they re-cored the radiator, the mechanic said there was a good bit of corrosion/blockage in the original radiator core.
I'm running out of ideas at this point.
Also, not sure about running "lean". Engine purrs like a kitten, no smoke at any time. Just don't want to risk anything until I get this cooling thing taken care of.
Okay. Have the Satoh 650G tore apart again. Not sure what's up. I also pulled the water pump off to make sure that it is working and it appears in good shape: Impeller spins, fins are all the same, hard to imagine that these go bad, but it was worth looking at.
Here's a question though, try and follow pertaining to the temp sensor issue:
there to two hoses: one from the water pump, and another from the thermostat housing, that run to a tee. From there, the coolant would travel through an intake through the engine ( I would suspect that this is what is circulating the coolant before the thermo opens up). Now, at this intake mentioned above, is where the temp sensor is located.
Is that the proper location for this to be? Was it modified to be here, or is this correct location?
Are there any specs to the water pump (since it is off) that I need to be aware of? If there is, please let me know, and I'll replace before putting it back together.
Other than this, I'm going to replace with a brand new thermostat, just in case. Would it hurt to put in a 160 or 170 degree vs the 180 spec?
2018 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A52705)
2018 CATERPILLAR...
2010 Komatsu WA320-6 Articulated Wheel Loader (A55787)
2010 Komatsu...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
Mobile toilet with shower (A55758)
Mobile toilet with...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
