Satoh beaver wont go into gear while running
   / Satoh beaver wont go into gear while running #11
If the clutch is stuck you should try high gear to break it loose not 1st, 2nd or reverce. This will put more strain on the clutch and be a lot more likley to break it loose.......Larry
   / Satoh beaver wont go into gear while running #12
I once had a car with 4 speed, to which I added a high performance clutch. So it had more pressure and a different compound (more steel) on the disk. OVERNITE, routinely, it would rust together if it rained, gauranteed. I could push the gearshift into gear, THEN start the car and it would instantly be moving, off I'd go. It would free up eventually while driving. This clutch did not slip, ever. Even at 50 mph shifting into 3rd gear, it would lay two patches of rubber for 50 feet. Fun for around town driving.
I think your clutch is rusted stuck together. Taking the tractor apart will not help. It is going to happen again if I am correct.
2015 FORD E350 16FT BOX TRUCK (A56129)
2015 FORD E350...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
2005 John Deere 310G 4x4 Loader Backhoe (A53421)
2005 John Deere...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A55302)
Greenworks...
Miscellaneous Vehicle Parts (A53425)
Miscellaneous...
