Satoh beaver wont go into gear while running
   / Satoh beaver wont go into gear while running #11
If the clutch is stuck you should try high gear to break it loose not 1st, 2nd or reverce. This will put more strain on the clutch and be a lot more likley to break it loose.......Larry
   / Satoh beaver wont go into gear while running #12
I once had a car with 4 speed, to which I added a high performance clutch. So it had more pressure and a different compound (more steel) on the disk. OVERNITE, routinely, it would rust together if it rained, gauranteed. I could push the gearshift into gear, THEN start the car and it would instantly be moving, off I'd go. It would free up eventually while driving. This clutch did not slip, ever. Even at 50 mph shifting into 3rd gear, it would lay two patches of rubber for 50 feet. Fun for around town driving.
I think your clutch is rusted stuck together. Taking the tractor apart will not help. It is going to happen again if I am correct.
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A53422)
2012 Chevrolet...
2021 CATERPILLAR 259D3 SKID STEER (A52706)
2021 CATERPILLAR...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A55851)
2019 Caterpillar...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
