SATOH BUCK S-470D release bearing spring.
   / SATOH BUCK S-470D release bearing spring. #1
JJVLS
Satoh Buck S-470D
SATOH BUCK S-470D.
I"m replacing the clutch. I have it ready to slide back together. When I split it the release bearing return spring was hung up.
When I got it off the bearing did not see where it came off of the Trans tunnel. The manual I have does not show the spring.
There is a hole in the tunnel. But I cannot see any wear spot or hole it should connect to on the tunnel.
So any help is appreciated.
:pullinghair: Thanks JV
Thank you I will call them.
Roadworthy Thanks again.
Big shout out to Valley Power Products. They are some great people.
Called them, their Mechanic was out on lunch. He called about a 1/2 hour after my call. Now I will wait for a new spring
that I ordered from them.
Still can't locate where the spring attaches.
What I'm I getting into dropping the transmission tunnel?
Thanks JV
   / SATOH BUCK S-470D release bearing spring. #6
Well getting the tractor back together. So I'm taking my time and checking things out.
Found left brake frozen. No big deal, pulled drum leaky seal. :banghead: So the question is do you remove
the final drive case and this pushes the seal off? :confused: The manual is not to clear on this.
Thanks in advance for any input.
   / SATOH BUCK S-470D release bearing spring. #7
Valley Power to the rescue. :cool2: :drink:
5TH WHEELS & HUBS (A55745)
5TH WHEELS & HUBS...
2018 DRAGON ROLL OFF TRAILER (A55745)
2018 DRAGON ROLL...
2023 54ft Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54ft Hooklift...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A53421)
2023 Caterpillar...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56129)
2019 FREIGHTLINER...
2018 FREIGHTLINER CASCADIA SLEEPER (A56129)
2018 FREIGHTLINER...
