SATOH BUCK S-470D release bearing spring.
   / SATOH BUCK S-470D release bearing spring. #1
JJVLS
Satoh Buck S-470D
SATOH BUCK S-470D.
I"m replacing the clutch. I have it ready to slide back together. When I split it the release bearing return spring was hung up.
When I got it off the bearing did not see where it came off of the Trans tunnel. The manual I have does not show the spring.
There is a hole in the tunnel. But I cannot see any wear spot or hole it should connect to on the tunnel.
So any help is appreciated.
:pullinghair: Thanks JV
Thank you I will call them.
Roadworthy Thanks again.
Big shout out to Valley Power Products. They are some great people.
Called them, their Mechanic was out on lunch. He called about a 1/2 hour after my call. Now I will wait for a new spring
that I ordered from them.
Still can't locate where the spring attaches.
What I'm I getting into dropping the transmission tunnel?
Thanks JV
   / SATOH BUCK S-470D release bearing spring. #6
Well getting the tractor back together. So I'm taking my time and checking things out.
Found left brake frozen. No big deal, pulled drum leaky seal. :banghead: So the question is do you remove
the final drive case and this pushes the seal off? :confused: The manual is not to clear on this.
Thanks in advance for any input.
   / SATOH BUCK S-470D release bearing spring. #7
Valley Power to the rescue. :cool2: :drink:
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
TAKEUCHI TL12R2 SKID STEER (A52705)
TAKEUCHI TL12R2...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
2018 Kenworth T680 Tri- Axle Dump Truck (A55788)
2018 Kenworth T680...
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
2010 Chevrolet Tahoe SUV (A55758)
2010 Chevrolet...
