Scag / Kohler engine has me stumped
   / Scag / Kohler engine has me stumped #21
What happens if you pull the trigger wire going to the starter solenoid while leaving the key in start?
Aaron Z
Yeah, I think a jumper wire test is in order....
If I'm understanding all of the posts correctly, it sounds like the engine fires right up normally in "start" mode, but then shuts off immediately when you release the keyswitch to "run" mode.....That sound to me like you do not have the "run" circuit energized at the engine and it is only firing off the "start" juice.....I would hot-wire the "run" circuit at the engine -- find the to connection for power going to it and put a jumper to it right from the battery. Then "run" will be live all the time and eliminate the possibilty of a cut wire / bad switch. If this test proves the engine will run, then you will probably find (since it sounds like you put in a new keyswitch allready) that you ran over a stick or something that went up under the machine and damaged / cut the "run" circuit wire between the keyswitch and the engine somewhere.
   / Scag / Kohler engine has me stumped #22
I think the SAM or electronic module is bad. It takes a special tool to test the SAM. Go to section 8 of this service manual for your engine and review the test procedure. http://www.kohlerengines.com/onlinecatalog/pdf/SM_CH18_CH750_1_11.pdf. Your Dealer Service Department should have one of the testers. If not, try another repair source. Paying someone to test the SAM would be better than blindly buying one.
As suggested I have done a jumper wire test putting 12v to the connector that feeds the ignition components, thus bypassing the switch and all circuits on the Scag side of the connector. The engine runs so long as I keep power on that. I think this narrows down the problem, and I'm going to jury rig it with a jumper to get some desperately needed mowing done. But the fix still eludes me.
The wires on the Scag side of the connector are all well-protected and there is no visible damage. I have to suspect the problem is in the Scag-side electronic module, part # 483029, which interconnects the ignition switch, safety switches, diode and relay, but really don't want to spend over $100 for a new one unless I'm sure it's bad. I have been unable to find an online service manual for the Turf Tiger. Anyone have any thoughts on how to test the electronic module?
Oh, man, do I ever feel foolish, but I have learned something: Never trust a visual inspection to determine that a fuse is good.
The first thing I had checked when the mower stopped was the fuses. They both looked good. After having done the jumper wire test I put a multimeter on the fuse for the ignition circuit. No current was getting through it. It still looks good, but I replaced the fuse and the mower now runs.
So, a visual inspection may tell you that a fuse is blown, but don't trust it to determine that a fuse is good.
I sincerely thank everyone who offered up comments and suggestions.
A new problem has surfaced, but hopefully I can sort it out myself. Again, thank you.
   / Scag / Kohler engine has me stumped #25
I have a 6 year old Scag Turf Tiger Kohler 27 engine. It has two 20a spade fuses. It will definitely start and stay running as long as I keep it in the "cranking" position. Only thing is, the starter is being kept engaged. So I replaces the ign/starter switch. Nope.... same problem. I am noticing that either or the other fuse blows after replacing one or the other. I then disconnected "every" safety switch, ammeter, relay, starter and connectors. The only thing that makes any sense at this point, after pugging and connecting each piece one at a time, is the relay!! That is my next step tomorrow. If not the relay... down it will go to my Scag dealer. He's a good guy and won't hurt me $$$ !!!
Trubbleshoeten - Before you take to your dealer and spend money . . . What I finally discovered was that the electric PTO clutch had failed and was shorting out, and that was blowing fuses. Your symptoms sound the same as mine, and I went through all the steps (mis-steps?) you describe. I replaced the clutch and have had no problems since. Does yours blow the fuses after you pull the PTO switch, or before? If it is after, that indicates the problem is after that switch. If you have an Ogura clutch, look at http://www.ganos.com/electricclutchadjustment.pdf for test procedures.
   / Scag / Kohler engine has me stumped #27
aloa Thank you. I will check out the clutch tomorrow (Saturday). The following is exactly as it occurred. My Scag Turf Tiger has been in my garage having its deck replaced. While I have been assembling the new deck with some of the parts off the old deck I have been starting the engine at least twice a week for five minutes. Just recently I went to start it and the starter just "clicked" away with that rapid sound it makes when the battery is weak. I checked the battery> weak>disconnected it>trickle-charged it> re-connected it and then the starter didn't even "click". Being a 6 year old battery, it was well passed its time. Installed a new battery and nothing. Checked fuses and one was blown. Installed new fuse and out blew the other, then the other... back and forth. Being that I hadn't even touched the PTO I can't imagine the problem being the clutch. After I re-install the deck tomorrow with the drive shafts hooked up, I'll check out the clutch. Seriously though, I am a firm believer at this point that it's the electronic mod ($90) or the relay ($13)... or both!
thanks trubbleshoeten
Trubbleshoeten - Your additional details sound different from my experience, so I agree that my fix probably will not be your solution. Maybe someone else has an idea. You might also want to check the repair forum at lawnsite.com for ideas. There is nothing quite as frustrating as an electrical problem.
   / Scag / Kohler engine has me stumped #29
I am going back to working on putting it back together tomorrow.... I have been involved with a different project since just before Mother's day. I don't recall if I have informed you; but, after another discussion with my local Scag dealer, he determined that my problem would be with my stator. Sure enough, 1 hour later> magnets were all off the flywheel and clinging to my "damaged" stator. SO... new voltage regulator, flywheel and stator. Now to re-assemble it all and get back to some 5 acres of seriously need mowing! Again, thank you for your help and, please, spread the word about my problem and the fix. take care.
   / Scag / Kohler engine has me stumped #30
ME AGAIN WITH AN UPDATE: So, 5/21/13> new stator, flywheel, and voltage regulator> all installed. Started right up... 2 minutes into mowing and bamm: dead again. Replaced fuse. Another 5 minutes... again, DEAD. My hands went up in the air and I proclaimed: "I'm done... so done"! Now it's down at the shop. Still my headache, but now it's being shared. Hey, what are friends for ('cept, this headache comes with an invoice.... soon to be "a-hurt'n". Hey, I'll let u guys now the results... hoping to save you a headache. (hey, what are friends for!) Did I say that already?
2016 Ford Transit Connect Van (A46683)
2016 Ford Transit...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A48561)
Toyota 6FGU25...
John Deere Z915B (A47307)
John Deere Z915B...
2010 Nissan Sentra Sedan (A46684)
2010 Nissan Sentra...
2010 Gleaner 9250 Draper Head  30' with Crary Air Wind System (A48561)
2010 Gleaner 9250...
Future Excavator Ripper (A47809)
Future Excavator...
