Heavy Metal Doctor
- Joined
- Sep 12, 2007
- Messages
- 139
- Location
- Mason Dixon Line
- Tractor
- Kubota L3301 w/LA525 loader, old IH Cub Cadets - 1250, 105, 124, Ferris IS1500z
What happens if you pull the trigger wire going to the starter solenoid while leaving the key in start?
Aaron Z
Yeah, I think a jumper wire test is in order....
If I'm understanding all of the posts correctly, it sounds like the engine fires right up normally in "start" mode, but then shuts off immediately when you release the keyswitch to "run" mode.....That sound to me like you do not have the "run" circuit energized at the engine and it is only firing off the "start" juice.....I would hot-wire the "run" circuit at the engine -- find the to connection for power going to it and put a jumper to it right from the battery. Then "run" will be live all the time and eliminate the possibilty of a cut wire / bad switch. If this test proves the engine will run, then you will probably find (since it sounds like you put in a new keyswitch allready) that you ran over a stick or something that went up under the machine and damaged / cut the "run" circuit wire between the keyswitch and the engine somewhere.
