Well I bought one! HMD904. Found one on ebay that looked to be in very good condition and included a few annular cutters for $500. I will try it out and see how it works for me. If I don't like it I am sure I can sell it and get my money back.
I bought a Champion RotoBrute AC35 from Amazon in December. The manual warns about weak holding below 1/2 in, etc.. There are cheap annular cutters on line. I saw some threads where guys have made small "drill press" forms in which to securely mount the magnetic drill. Mine came with a safety chain. Some guys have used a 1/2" or thicker plate that clamps or screws or bolts in place. The slightly larger Champion RotoBrutes have a variable speed and reverse so you can use their bit sets wherein on single bit predrills, cuts threads and backs back out of the hole, all in one function. The cheaper AC35 that I bought is just as heavy duty, but no reverse and runs only at about 700 rpm. For me it's a great alternative to the drill press. I'm planning on making a small drill press mount for it thought, to be able to use the chuck for smaller diameter drill bits.
The chuck attachments available are great, but almost touch the base level on a flat surface. That's why some ppl have used heavy plate to make a "stand off" mount so it can be used with the standard chuck for smaller diameter holes.
The standard 3/4" Weldon shank annular drill bits only go down to 1/2" and most kits bottom out at 9/16 ". I got mine to drill the holes in base mounting plates PRIOR to cutting them and welding them in place. Also, working on large farm equipment, it's nice (if there's room) to place precision holes. The AC 35 does well in making frame hitches, etc..
