Sea Foam in hydraulic sys
   / Sea Foam in hydraulic sys #11
I have used the water absorbing filters. You have to watch the return pressure because it will rise as the filters catch more and more water.
What you say is true, and will absorb small amounts of water. Does the color of the fluid change from milky back to new looking fluid?
Do you know if the filters are absorbing free water or is it removing water from emulsified fluid?
If you looked at the 4 jars of fluid collected from different stages of fluid cleaning, that was not done by heating alone. They probably used a combination of vacuum, centrifuge, absorbing medium, and other extraction processes.
What they don't say, is anything about the compounds that were changed.
Does the fluid meet the same specs as new fluid. Some of the additives would almost have to be replaced, and only a full analysis would tell one this data.
Cooking fluid in a turkey cooker to make the fluid like new is just a back yard mechanics dream. It just ain't going to happen.
Would you let someone try and clean up your contaminated fluid by backyard experimentation, and put it back in your tractor?
   / Sea Foam in hydraulic sys #13
I'd almost have to guess that the emulsifiers, and perhaps detergents would be used up!
soundguy
   / Sea Foam in hydraulic sys #14
I have to think that cooking the oil would be something similar to gave a few drops of water in cooking oil. Everything is fine till the oil reaches above 212f and the water turns to steam which a loud pop and blows a bunch of oil out of the skillet. I would think the same would happen with the turkey frier. Maybe a pressure cooker type of vessel would hold some of the exploding oil inside while releasing the water vapor. I cant see heating the oil to 250F is going to hurt it as it has to get much hotter than that before it would burn off. Anyone with an old electric skillet and some milky hydraulic oil, might try setting the thermostat for 275F and cooking some to see what will happen. I would do this outside though and keep an eye out for the wife.:laughing: Lots of soap would clean it up afterward.
Where are you getting your figures for vaporizing/boiling water. I always thought it was 212 degrees.
I am thinking 275 degrees will destroy/burn the fluid and leave you with a big mess.
I think you are setting up some unknowing individual for a good scalding.
If you have good knowledge of this process of cleaning up emulsified fluid, perhaps you can try it and produce a working paper on the process, and perhaps get a patent on this concept.
   / Sea Foam in hydraulic sys #16
You do not have to get the oil anywhere near 275, you can remove the water at 180 or 200 (Evaporation) It will take longer but it will come out.
Remember, manufactures want you to run generators and engines regularly to remove moister from the fluid in them and they only get up to 190 maybe 210
Big equipment use scrubbers on hydraulic oil all the time, of course they have 50 or more gal in them.
Most systems I have looked at use vacuum and heat to increase speed. Some do it like a kidney (setup on the side of the machine while it is in use) others remove most of the fluid, clean it replace it repeat
This is an example
Washington Marine Cleaning
Excerpt from the above link, and says what I have been saying all along. .
[ There are different approaches to removing water i.e. absorptive filtration, centrifuges, and coalessors. These three methods will remove free water from the fluid leaving dissolved water behind. The only method for complete water removal from hydraulic fluids is Vacuum Dehydration. It just so happens that I don't posses one of those units, and I can probably guess that none of you have one ether. ]
Notice that the top three will remove free water, and that is water that has not been emulsified.
It is just not practical to suggest the layman or tractor used can or even should attempt water removal. Preventing water entry would be the best policy.
The facts above are proof that you and I can not achieve what you are thinking, to recover nasty oil that has been emulsified, and use as new or good oil in a money saving adventure.
   / Sea Foam in hydraulic sys #18
Don't try this, without some serious thought... However....
Boiling point of water is 212 (at sea level) due to atmospheric pressure.
If you reduce the atmospheric pressure, the boiling point goes down, (rather rapidly) SOOOOO.... if you put your contaminated fluid in a container and put a vacuum pump on it, the water will boil off at room temperature. This is done in the HVAC business all the time, but I don't recall ever hearing of anyone trying to do it with contaminated fuel or hydraulic fluid.
When I was in HVAC school, I took a piece of 1.5" aluminum and milled a hole in it, then drilled and tapped holes to mount Lexan to both sides. Then added a fitting to hook a vacumn pump and filled the hole 1/2 full of water. Turned the pump on, and as pressure dropped, the water would start boiling (at room temp). Drawback was I needed some way to keep the water from contaminating the oil in the vacumn pump, such as an in-line can cooled with ice to drop the temp enough to reliquidfy the steam to liquid before hitting the pump.
David from jax
Crackle Test.
This is a qualitative test for the presence of water that may be performed tank side. The Crackle Test is conducted by placing the fluid on a hot plate or even in a small piece of aluminum foll which is heated with a match using appropriate eye and face protection, as the fluid will make a "crackling" sound and spatter if it contains water.
Could also use hot exhaust pipe .
I used Dragon Naturally Speaking to enter this text. Seems to work fairly well but had to correct some mistakes.
It only cost me about $39 with rebate from CompUSA.
   / Sea Foam in hydraulic sys #20
Crackle Test.
Dragon N/S has been around for quite a while. I installed one of the early copies when I was heavy into building computers and playing with them way too much, back in the 90's. Program started out hard to install, but I am sure they have gotten that worked out, or maybe I am just getting better at installing programs, lol.
Cell phones now use basically the same thing for texting and email messages, and like the Dragon, does require some edits, but they really are getting better at it. For computer conversations and posting, the Dragon works good for people who aren't typists. My sister tried it for some of her work, but it slowed her WAY DOWN, but she types in excess of 130 words per minute. Me, I am lucky to get 20 (corrected wpm)
David from jax
2018 Kaufman 20-Ton Equipment Trailer, VIN # 5VGAP2528JL004708 (A57453)
2018 Kaufman...
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
IRanch High End Mini Golf Cart (A57149)
IRanch High End...
2011 INGERSOLL RAND  G25 GENERATOR (A58216)
2011 INGERSOLL...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
1617 (A58375)
1617 (A58375)
