Seafoam
   / Seafoam #223
wow, Sound guy really was on the mark about this dude
   / Seafoam #224
WM had a roll back sign on Sea Foam so I guess it is $7.97 now.
For the longest I could only find it at NAPA but the current owners to it to many retailers.
i see wm is now carrying an stp product.. about 3-4$ per can. I requested a msds... i bet it turns out to be a similar mineral oil / naptha / alcohol, type mix... or something along those lines.... just cheaper . w'll see when the msds arrives.. :)
   / Seafoam #225
Instead of adding Seasuds just add IPA to the fuel tank to absorb water and dissolve gum. Then again today's gasoline does not leave deposits like leaded road has did 30+ years ago.
   / Seafoam #226
I saw that at WM the other night setting next to the Sea Foam. Thanks for digging into the details and let us know what you fine.
Nothing that I have tried works better than Sea Foam for the price yet the same results at 50% less would be of HIGH interest to me. :)
A lot of Sea Foam is being sold at $60-70 a gallon so it may have caught the attention of the company owning the STP brand today. Reverse mixing the chemicals would be a very LOW brainer.
   / Seafoam #228
yea i saw that, i think its in the same type bottle. I saw it about a month ago. i think it was $4-5 maybe. It was right next to seafoam and B-12
   / Seafoam #229
i bought some.... havn't used it yet...
i wonder how it prevents rust in the fuel system without an alcohol addative to dewater...
Diphenylamine i don't think is water soluable... ?
   / Seafoam #230
Does not sound like bad stuff but still looking for it automotive uses info.
Diphenylamine is used as a pre- or postharvest scald inhibitor for apples. Its anti-scald activity is the result of its antioxidant properties, which protect the apple skin from the oxidation products of alpha-farnesene during storage.
Did find the below use for Motor Oils
http://www.lubrizol.com/CorporateResponsibility/DiphenylamineAntioxidants.html
Does it antioxidant properties keep fuel from aging as fast?
http://www.fueldispensersworld.com/info/T557-Octyl-Butyl-Diphenylamine_1381.html
It seems to be missing the light oil in Sea Foam which is about the only thing that does not burn off when Sea Foam is used in the crankcase if I remember correctly.
2008 Ford F-350 Service Truck (A53422)
2008 Ford F-350...
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A54607)
2022 BRAZ0 40FT...
2021 JOHN DEERE 648LB SKIDDER (A51406)
2021 JOHN DEERE...
2018 Ford F-150 Crew Cab Pickup Truck (A53422)
2018 Ford F-150...
2021 TAKEUCHI TB235-2 EXCAVATOR (A52706)
2021 TAKEUCHI...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
