Eagleview
Veteran Member
If a quick connect on the drain hose comes apart , don't let the mulcher stop . If it's on an electric solenoid servo , idle the machine down with the mulcher still running . After your usual Turbo cool down time , turn the engine off . If it's on a pilot line pedal , idle the engine and slowly let the pedal return to neutral . By doing this no harm will be done to the hydraulic motor . The harm is done when the oil flow is shut off suddenly with the rotor still spining , the motor "dead heads" and either the seal will blow or the case will crack .
