Seasonless and Idle Tractors ...
   / Seasonless and Idle Tractors ... #31
SNOW???:confused: Not sure what that is. Could someone describe it? Sounds like there has been some opportunity for some of you snow states to get some extra work done before spring. Here, business as usual, although the rain has made it a bit unpleasant for anything but indoor work. Tractor is just waiting for a sunny day to get some dirt work done.
Stay warm and dry.
   / Seasonless and Idle Tractors ... #32
I'm taking a little vacation here in the Lakeland, FL area and was just telling my wife how I missed fooling around with the tractor. I was reading an article in the Tampa Tribune and they were talking about the unusually warm weather. It has yet to get below 45 F this Winter. This is the first time in 73 years it has been this warm. The mosquito population has been flourishing without having to deal with any cold weather. If I had the tractor I could run all the skeeter's over! I'll have to talk her into bringing it down here next year.:)
John
   / Seasonless and Idle Tractors ... #33
Just happened to be checking out some pic from KSN.com, a news network in Kansas where my wife's family is from and found one that may make some of you guys concerned about not having to move any snow to mover around feel just a bit warmerr. Don't know who took it but downloaded it from KSN.com this morning. It was taken around Christmas time when Eastern CO and Western KS got it pretty hard with snow. Makes one feel a little warmer not having to have to deal with that very often.
   / Seasonless and Idle Tractors ... #34
FiremanPat
You got the gift. Checked my local weather (centrl MA) and they are calling for 1 to 3 inches on Monday night.
Don't know if it is going to be enough to try my new tractor moving snow, but hey I have learned not to trust the forcasters. I Hope your trip goes well.
Dan
   / Seasonless and Idle Tractors ... #35
daTeacha said:
I'm hauling a load of firewood into the pass-through from the garage about every 3 days, have cleaned the "used hay" out of the sheep shed twice, and just recently used mine to direct the fall of an ash tree to make room for a coming landscaping project. That was kind of interesting, rigging a chain up the tree, a cable to the chain, a snatch block around another tree, and then the tractor to the end of the cable to do the pulling. The tree missed the mark by about 10 degrees, but it didn't land on the house, which was the main object. Then came cleanup and firewood making, again using the tractor, so mine's been seeing some use despite the lack of snow.
I grubbed 6/10 acres with mine last winter thanks to almost all of Jan and Feb being 50 60 and 70 degree days.
Snow and cold would have shut down that project.
   / Seasonless and Idle Tractors ... #37
here in central FLA there aint no putting the tractor away. good thing this time of year is the grass is pretty much dormant but I been using the boom pole on the back of the tractor to pull up some fenceposts.
been busting up some groound for a new garden,,, sod is ten inches thick so I have plowed that area four times now this winter.
been here 10 years and found out our fence is ten to 20 feet on the other guys property, since he was planning on running a new fence, I been pulling out the fenceposts, at least where I can get to them. some of the property is so overgrown it aint EZ to get to em with the tractor.
   / Seasonless and Idle Tractors ... #38
With this very, very boring winter season (5" of snow total) so far I have taken to starting and running the tractor about every two weeks. We have had some sub-zero temperatures recently and today was the first day that went very briefly above freezing. I started the tractor with little difficulty (had to preheat 2X), let it warm up for about 5 minutes, dumped the ice that had accumulated in the front bucket, and drove down the driveway to get the newspaper (That's so sad :(). On the way back the tractor started to rough idle, miss, and finally died :eek:. I had added Power Service White to my fuel tank as well as my last 5 gallons of diesel. I get my diesel from the same gas station as the local school buses so I believe they seasonally switch diesel fuels. I checked the sediment bowl/fuel filter and discovered that the fuel had gelled. As I had just replaced the filter at 50 hours I was unwilling to pull and clean it. I got out my old trusty heat gun and extension cord long enough to get to the tractor. 10 minutes of warming the sediment bowl and the fuel was liquified. The tractor started back up and ran without problems for the next half hour. I am hoping that the fuel that gelled was residual fuel from the summer. This Mondays' storm will probably track too far east to affect me, but it appears that there will be a coastal storm forming around Groundhog's Day. I have around 200 feet of extension cords available and I will keep any plowing if any to the 200 foot range :(!
   / Seasonless and Idle Tractors ... #39
I think I have a worse problem. The weather stayed warm so long I got most of my projects for the tractor done :( . By May the only I will have to do is mow the yard :mad: . I told the GF I should buy the property next to me for an investment. She saw right through me. She said that was a lot of money to spend just so I could play with my tractor. Maby if I start to till up the yard again she will change her mind :D
   / Seasonless and Idle Tractors ... #40
You have to finesse "She Who Must Be Obeyed" not so :cool:. Jay
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A53473)
DeeZee Crossover...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
