Seat switch on 2310
   / Seat switch on 2310 #11
I've been using a jumper wire on mine since about week 1. My dealer told me that most of their customers have the switch jumpered (although they did not condone this). To me, the seat belt serves largely the same purpose that the pressure switch does.
One thing I won't do is bring my seat in the house every time I park it in the winter.
   / Seat switch on 2310 #12
shawn1533 said:
What if you are too light like my wife?
There is a problem, I would love to have. :D
   / Seat switch on 2310 #14
I guess I can not complain. To solve the problem I will add a switch to bypass the seat switch when I need it. I have had it shutoff on me when I was backing it into the shed while looking backwards.
   / Seat switch on 2310 #15
(Whisper) Disconnect the switch, just don't tell anyone. if you do, you will bring on the rapture. (end whisper)
   / Seat switch on 2310 #16
:D - Ray!
I'll be bypassing mine soon too. My 15 year old daughter uses my tractor on ocassion and as she hits bumps and bounces and such, the tractor will die. :rolleyes:
   / Seat switch on 2310 #17
There has to be a fix for this besides "by-passing" it. I am a firefighter and no one yet to date has ever and I mean "EVER" called 911 because they did something brilliant. I have been on some hills on my 2300 and even when I re adjust my seat for viewing I never had this problem, may stall for a sec while I hop on the seat but never seen it not work. Guys and for your "gals" sake find a fix before cutting it out as I have seen severed toes from a lawn mower and also seen what a snow blower does to a glove cover hand when inserted to a snow blower. :mad:
   / Seat switch on 2310 #18
Yes, no one should disconnect the seat switch.
   / Seat switch on 2310 #19
I am on my second switch which quit working durring the last big snow we had.
Yes mine is currently bypassed but I intend to find a way to make it work correctly in the near future.
BTW: I am quite confident it is not because I am too light.
   / Seat switch on 2310 #20
I had to do something with the seat switch on my tractor because I couldn't run my PTO powered post driver. It would have taken someone in the seat and someone to drive the posts if I had left the switch the way it was. I put a push button on/off switch on the lines going under the seat. I used bullet connectors so that I could take the switch out and reconnect the original wires if I ever wanted to. I don't have a picture of it but I mounted the switch in a painted aluminum angle under the side of the seat so that it would be easy to get reach.
[FONT=&quot]Seat Switch wiring
I just have to remember to turn it back on after use.
[/FONT]
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
2014 Ford Taurus (A56859)
2014 Ford Taurus...
Water Line Hose (A59076)
Water Line Hose...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
2016 Komatsu PC360-11 Hydraulic Excavator, S/N A35687, PIN# KMTPC256CGWA35687, Turbo Diesel Engine, (A59076)
2016 Komatsu...
8 sets of Jumper Cables (New/Unused) (A59225)
8 sets of Jumper...
