( SEAT TIME ) Why you need a grappler for tractor
   / ( SEAT TIME ) Why you need a grappler for tractor #1
Cat_Driver
Coachella Ca.
2016 Kubota 4060, 2017 Tackeuchi excavator TB260
For me a grappler is like a giant pair of hands that can pick up things and do as you wish. My most favorite clean up tool. :thumbsup:
That's a Palm Tree I'm tossing on the pile.
   / ( SEAT TIME ) Why you need a grappler for tractor #2
I've got the grapple now and agree it is now and will be my most used implement. Now I need one of those Cats!
I had to switch to a track tractor. I have a Date Palm grove and the needles on the date trees are like a stiletto knife and as sharp. I was fixing flat tires on a weekly basis, Last set of new tires had more patch than tire. Nothing worse than getting all ginned up to spend some quality time doing some work then five minutes later you get a flat.
I read here that someone called these things the Victorinox Swiss Army of tractors, and that statement have proved more than true.
The part I like is sitting in the cab, hitting a button and switching buckets or forks, or cranes with the flick of a switch.
Heck with the Kubota I has just to switch buckets was a chore, lining up the pins just right.
Then I put this grapple on the Kubota and by the time the Kubota lifted the grapple it as nearing it's max lift capacity.
It was hard for me to get out of the traditional tractor mind set, but I don't plow or cut grass so it was a no brainer.
Makes quick work of clean up - I know that much . Spinning on a dime doesn't hurt either for maneuverability.
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
BUNDLE OF 6" I BEAMS UP TO 8' (A54756)
BUNDLE OF 6" I...
2021 TAKEUCHI TB240 EXCAVATOR (A52705)
2021 TAKEUCHI...
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
WACKER NEUSON EZ36 EXCAVATOR (A52705)
WACKER NEUSON EZ36...
