Seed drill build thread
   / Seed drill build thread
Seed boxes attached now, conducted rip tests yesterday with the machine coming up trumps, now just the metering roller drive and she's ready to get 10acres done asap
   / Seed drill build thread #12
watching with interest.
any chance for a couple extra photos of the seed boxes?
   / Seed drill build thread #14
inside boxes and pipe going through boxes. looks like you are planning some sort of 'auger' to unstick seeds in box and get them to drop down the outlet to each hose?
   / Seed drill build thread #15
Hi ! You make a very good job. I like your coulters and pressure wheels. But for the seeder. With Electric motor you have no direct ratio with ground. May be you dont need precision seed. You could add a Mountain bike wheel with grip tire rear for drive your seeder. These wheels can have six or seven gears for adjust seed with soil . Easy and inexpensive way for drive and good precision.
I dont know if a single disk just before coulter could improve the set. This disk could cut soil and roots , pass over rocks .
Thanks for share, Good luck! Oldmech
Here are some more pictures getting very close to calibration and running out seed onto paddocks.
Seed metering rollers are made from hard Australian box timber. Slots were milled in with a carbide router bit. Plastic pipe is Australian class 12 high pressure pvc pipe.
Seed boxes are a special high grade quality with a Teflon laminate inside making them completely non stick.
   / Seed drill build thread #17
So you're making a shoe planter. Looks like a good unit. Nicely done.
Sown 10 acres with the machine today, did quite well although the Tyne springs are going to be modified to a rubber compression block system as at 10kph behind the bike they are struggling a bit. Seed metering worked perfectly with the rate bang on what I calculated. Hoppers are a bit on the small side for oats, but it's quick to dart across the paddock and refill. 285kg of seed through the machine.
Will keep you posted on some new pasture openers
   / Seed drill build thread #19
awesome! is that a peddle bike gear setup there? so you can adjust rate of seed?
It was originally a bicycle chain setup however that failed completely during the wear in phase, the gears just couldn't handle the torque needed to turn over the rotors, now I'm using a 1/2pitch chain. It's working a dream and just purs along quietly. I am also doing a small seed air powered pasture seeder to mainly do rape seed and fine seeds.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 Deere 50G (A53317)
2020 Deere 50G...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
large capacity skid steer bucket (A56857)
large capacity...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
