Seeding a steep slope
/ Seeding a steep slope #1
trlong
Platinum Member
Vermont, USA
J.D./4115
I have been filling in a steep area (approx. 80' X 80') below my house, in an attempt to shape it for mowing with the JD 4115 and grooming mower. I've added and graded about 200 yd.s of "Overdurden" and sand, so far. I'm almost ready for topsoil but with heavy summer rains, I have already had considerable wash down of some of the fill. /forums/images/graemlins/frown.gif
My questions is, does any one know the name(s) of the grass seed/straw/mesh that highway departments often use on steep slopes to prevent erosion until the grass has taken hold? Also, if any one knows sources, relative costs compared to aternatives such as heavy mulch straw, I would appreciate the information.
I have pictures of "before and after" to this point but, I was waiting until I am able to show the "finished project" to post.
Thanks,
Tom
/ Seeding a steep slope #2
I don't know of any brand names, but I've used 2 different products on my property, one was a fiber mat with a poly mesh, the other was a straw mat with a poly mesh. The fiber mat is better for erosion control while trying to establish grass seed, I bought it at a local feed store. Right now I am using straw mats to help establish new grass on a mild slope I just regraded so I can run a fence line through it. The straw mats were just under $60 a roll, they were 7' by 120' if I recall correctly. I bought them from my local fertilizer/mulch/stone yard. I suspect any feed store would also have them.
Bob,
Thank you. I'll check with a couple of feed/supply stores. I may have to go with a combination of fiber for a couple of steep slopes that I will never be able to mow (sides of slope area and 1st step from house level) and the "waterbar/path" I'm trying to grade in. I may go with the straw for the large, less steep area, especially if the staw is less expensive. All will depend on cost and my budget.
Again, thanks. I'll post some pic's when I get some grass growing.
Tom
/ Seeding a steep slope #4
The stuff they use out here is called Hydro-seed, they just shoot it out of a nozzle and it sticks to anything. It's seed straw & fertilizer, I have seen it grow grass on T-post..... /forums/images/graemlins/wink.gif
/ Seeding a steep slope #5
When I was Stationed at Edwards AFB in CA they used the hydro-seed some amazing stuff in about 2 weeks the yard was greener than a foot ball field and was about 4" high! spraied it out of a converetd looking fire truck! I never saw anything grow so fast for NEW LAWN that is... the weeds in my garden will grow 6" over night somehow but the tomatos and other stuff just wilts & crooks /forums/images/graemlins/frown.gif /forums/images/graemlins/crazy.gif
MarkM
/ Seeding a steep slope #6
Tom,
Along the road in our neighborhood we have a couple steep banks that cannot be mowed, we planted a grass called "Little Blue Stem" it is a native prairie grass that grows about a foot or so tall, but still looks fairly neat.
I have a spot that is a nightmare to keep up, we planted Crown Vetch which is a fern-like plant that spreads, chokes out weeds, stays under knee high and blooms with clusters of little pink flowers. They use it along the highways to cover steep banks that they don't want to mow. Little blue stem and crown vetch both seem to thrive in USDA zone 5.
You may want to try buffalo grass. It is a very low growing native grass from the prairies. Seed is expensive, but may be a great option for you too.
/ Seeding a steep slope #7
How about a couple of strips of sod in strategic layered positions? Then seed in between.
I did this on a slope I had. Worked very well too, I may add.
-Mike Z. /forums/images/graemlins/grin.gif
Bully and Spiker,
Thank you but, I don't think I can afford the equipment for spraying (without a trailer I can't even go rent one without paying drop off and pick up charge). Thanks for the name though, you never know what may be the most cost efficient in the long run.
Tom
Bob,
Thanks again. I've been looking at various grasses for both the steep and the less steep slopes. The little blue stem and/or crown vetch are good suggestions. I can't remember though if they are cool or hot season germination. I'll have to look at my notes as I missed the cool season and have to get some thing growing before fall. My wife is inclined to plant ornamental grasses, such as micanthus (sp?), along with some native ground cover (can't remember name but is similar but NOT Lisimachia (sp?)). We may need to get some thing like the blue stem or vetch established 1st as the ground cover plant takes time to spread on the steep slopes.
I facilitated a session on grasses and turf management a while back (VT Extension Service) and have the tape. I need to pull it back out and take better notes.
Tom
Mike,
Also a good idea but, I don't think I can afford the sod. I could be wrong though, so I will look into the cost and compare with the alternatives. To keep every thing from washing off while seed established, sod strips would be a good option if I can afford it.
Thanks,
Tom
/ Seeding a steep slope #11
Tom, IF I recall correctly (and since I recently got bonked on the head by a tree I admit my memory may be faulty) I believe the Crown Vetch is hardy up to USDA zone 3, Little Blue Stem is a native prairie grass and was found through the entire central plains area of the US, I suspect it is at least hardy to USDA zone 4. Buffalo grass is also a native grass, but it has been "improved" by several plant breeders, again I would suspect it is tolerant to zone 3, but definitely to zone 4. As I am in zone 5, I really don't check too deeply into plant hardiness after it is covered by my zone. As to when they actually germinate, I honestly don't know. I know we planted the Little Blue Stem in the summer and it grew, but I don't know if that was the correct time to plant it.
I have personally not used Buffalo Grass, but I talked to several folks who say it solved a lot of their problems, it is also naturally very short growing and will stay under 8" unmowed. I think it looks a bit ragged if not mowed, but on a bank, if it could be established would be ideal.
The crown vetch I purchased was bare root "crowns" (they looks like dead roots when I got them) and they were planted on 24" centers, they grew very quickly and filled in pretty well too. We now have too much and thin in back every year. But the trouble spot has since been planted with several hundred daylilies so we don't really need the crown vetch there anymore. We keep it becuase it is fairly attractive. I will be transplanting some behind by new garage/workshop because there is a slope behind it that is too steep to even get a tractor to climb. The crown vetch tolerates horrible soil, transplants easily, and is cheap to buy in modest quantites.
/ Seeding a steep slope #12
I have the same problem only on a larger scale. So far I have planted about 600 square yards. I used a cool season fescue grass mix from prairie nursery called "No Mow" combined with a straw mat that I bought locally. The no mow is expensive, but if it lives up to it's name it will be great. They also carry a prairie grass mix that i am going to seed over my geothermal installation and my septic field. This seed isn't cheap. The straw mat was $44 for 100sy and was well worth the $.
I did this all with a hand tiller and hand rakes. Too much! I bought a BX2230 because there is just too much to do by hand.
Maybe I can post some pictures in the next day or 2.
Good Luck!
Doug
http://www.prairienursery.com/
http://www.erosioncontrolblanket.com/products.html
/ Seeding a steep slope #13
<font color="red"> same problem . . . larger scale . . . 600 square yards . . .
I did this all with a hand tiller and hand rakes. </font>
Doug, you forgot to mention how many tubes of Ben-Gay and bottles of pain relievers it took to make the aches go away!
I have more tractors and power equipment than I actually need and my new neighbor asked me one day if I owned a tractor dealership. I told him "No, I just got tired of hurting myself by doing jobs by hand." Sounds like your motivation is the same as mine.
/ Seeding a steep slope #14
I spent an entire day Saturday, all day Sunday and 4 hours on a Monday night. There was a ton of aspirin involved, blisters on both hands and feet and I could barely move on Tuesday.
Never again!
I have 800 sy of hill left to do. I have the straw blankets and the seed. I plan on getting started this weekend. Landscaping is going to be my life this summer.
This is backbreaking work... Good luck and be safe to anyone who tries it.
</font><font color="blue" class="small">( [/color:blue]I did this all with a hand tiller and hand rakes. Too much! I bought a BX2230 because there is just too much to do by hand.</font>
Doug and Bob, I know the feeling. with three knee surgeries an elbow and a shoulder surgery I try to leave the hand tools in the shed, as much as possible, and do as much from the J.D. as I can. Here's a couple of pic.'s of what I'm trying to get into shape to mow, rather than swing a weedeater at every year. If it were'nt for the J.D., I'd be buying stock in Advil and Ben Gay by now :-(
I'll try to find some old pic's of when everything but the mound system (at bottom) was overgrown with sumac, before we began the "reclamation".
This one is just after starting to fill to make a "mow-able" slope".
Tom
This gives a better idea of the slope. This is after about 120 cu. yd.'s of fill.
OK, one more. This looking down from the deck for perspective.
Oops, wrong pic. Oh well, make that last one "Looking up slope toward deck".
P.S. Local landscape supply has had biodegradeable "Straw Mat Rolls" (6' x 100') and is checking to see if they have any left. If not, they can order. I'm waiting for and answer and a price quote. In the mean time, I'm checking on "warm weather germination" grasses and finishing the grade so I can get the topsoil on and rolled.
Thanks all, Tom
/ Seeding a steep slope #19
This is the before shot. I made the picture pretty small, but you can still get the idea how much we did in a few days.
/ Seeding a steep slope #20
This is the after. The straw blankets are easy to install. I may get a picture today after I mow. The grass came in pretty well.
I bought a Nortec Piranha PXT400 power rake yesterday. No more tilling and raking!!! /forums/images/graemlins/smile.gif
http://www.nortecmfg.com/piranharakes.htm
Doug
UNUSED RAYTREE RMT48-48" HYD TRENCHER (A62131)
UNUSED RAYTREE...
2014 Ford Focus Hatchback (A61569)
2014 Ford Focus...
2014 Kubota KX057-4 Mini Excavator (A61166)
2014 Kubota...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
New/Unused Two Wheeled Electric Bike (A61166)
New/Unused Two...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
