Semi with LOOOOOOOONG tank on tralier
   / Semi with LOOOOOOOONG tank on tralier #22
It was a stator for Cliffside Steam Station operated by Duke Power.
Total weight for the load was estimated around 1,000,000 pounds if I remember correctly. That was for everything. Trucks, trailers, load, etc.
It was so large that there was a crew going ahead and removing all cables and lines that crossed the road. Then another crew went ahead and put extra supports under some bridges or on some they would actually build another "bridge" to cross an expanse. Then another crew was dedicated for nothing but changing tires that had blown out during the day when the caravan stopped for the night.
On this particular load there was always 2-3 trucks pulling from the front and 2-3 more pushing from the rear. Each axle of the trailers was hydraulicly adjustable.
This load came from the sea port in Charleston, SC and went to Cliffside, NC in Rutherford county about a year and a half ago. It took them a couple of months to make the move. I wish I could remember all of the specs.
Wow...That must have cost a fortune...:confused2:
   / Semi with LOOOOOOOONG tank on tralier #23
I wanna see the crane that is going to place it.
Steve
   / Semi with LOOOOOOOONG tank on tralier #25
   / Semi with LOOOOOOOONG tank on tralier #26
I knew I'd seen it somewhere recently! :D
I thought the video would be a nice addition to your pics. :)
   / Semi with LOOOOOOOONG tank on tralier #27
There is a ridiculous amount of drilling going on in PA for natural gas. I'm sure it has something to do with that industry. Last time I travelled through, all I saw was trucks loaded with pipe, pumping rigs, and other associated equipment.
   / Semi with LOOOOOOOONG tank on tralier #28
That is the same load that I posted pics of, but it didn't weigh quite that much. It was estimated at right around 1 million pounds, not 1.9 million. It was huge none-the-less. It was just the stator also, not the complete generator.
Wow...:confused2:
   / Semi with LOOOOOOOONG tank on tralier #30
The load I posted a picture of was moved today.
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
2025 CFG Industrial MX15RX (A50123)
2025 CFG...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
2021 CASE IH 345 LOT NUMBER 196 (A53084)
2021 CASE IH 345...
2017 SANY SY365C LC EXCAVATOR (A51246)
2017 SANY SY365C...
