Septic tank lift station pumping question
   / Septic tank lift station pumping question
My lift station tank has an alarm that goes off in the basement if the float that it is attached to gets lifted up by the water height going too high. I set my pump to begin pumping just as the water touches this alarm float and cut out when there are a few inches of effluent left in the tank. When my pump failed, I just dropped another pump in to replace the old one, connected it to my outlet and off I went.
   / Septic tank lift station pumping question #13
We built an addition on our last house and were forced to replace the existing field with a larger one. This required the use of a pump tank. It had two floats. The pump float turned on the pump when the tank got about 1/3 full. The alarm float set off the basement alarm when the tank reached 2/3 full.
Also, I hope you do not have a 'sump' pump. It should have a sewage pump. Our sleezy contractor installed a 1 hp sump pump, even though the design plan called for a 1.5" sewage pump. The sump pump lasted one year. The sewage pump would pick up and pump a 1.5" rock if it needed to. It's still working about 15 years later. So much for the 'excellent' inspection by the code enforcement officer. /forums/images/graemlins/mad.gif
   / Septic tank lift station pumping question #14
2025 CFG Industrial MH12RX (A50123)
2025 CFG...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
15ft. Diamondback Airboat with S/A Aluminum Trailer (A51694)
15ft. Diamondback...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53473)
2016 Ford F350 -...
