Series designations? (M, L, B, X)
   / Series designations? (M, L, B, X) #11
Count your luck in North America. In Australia we get slugged for about 40% more with an equivalent $ exchange rate !
Nobody can explain why (freedom from competition)
   / Series designations? (M, L, B, X) #12
How about some more designations? (Quoted from Vic on OTT.)
BX Series
V = Loader Valve
T = Turf Tires
R = R4 Industrial Tires
LB-T = Loader Backhoe w/Turf Tires
LB-R = Loader Backhoe w/R4 Tires
B Series
E = Two Wheel Drive DT = Dual Traction 4wd
HSE = Hydrostatic Transmission, 2wd
HSD or HSD-1 = Hydrostatic Transmission, 4wd
HSDB = Same as Hydrostatic 4wd, but includes Bi-Speed turn
HSD-T = Hydrostatic Transmission, 4wd, Tow Tractor (Airlines)
TL = Tractor, Loader
TLB = Tractor, Loader, Backhoe
L Series
DTC = Dual Traction, 4wd, Two stage clutch, Live continuous Running PTO (L235/L275) DTC = Dual Traction, 4wd, Integral Factory Cab (L3600/L4200) DTN
DTS = Dual Traction, 4wd, Power Steering
DTSC = Dual Traction, 4wd, Power Steering, Two stage clutch, Live continuous Running PTO (L235/L275)
DTN = Dual Traction 4wd, Narrow Specialty Tractor DT-W = Dual Traction 4wd, (W) Wet Clutch = EVER CLUTCH
F = Two Wheel Drive
FS = 2wd, Power Steering
FC = 2wd, Live-continuous running PTO
FSC = 2wd, Live-continuous running PTO, Power Steering
FST = Fully Synchronized (Main) Transmission
GST = Glide Shift Transmission
GSTCA = Glide Shift Transmission, 4wd, Factory Cab, "A is for Air Ventilation Kit (L3600/L4200)
GSTC = Glide Shift Transmission with Integrated Factory Cab
HC = High Clearance (L245HC only)
HF = Hydraulic Shuttle, 2wd
HDT-W = Hydraulic Shuttle, Dual Traction 4wd, (W) Wet Clutch = EVER CLUTCH HDT = Hydraulic Shuttle, Dual traction
HSTC = Hydrostatic "Feather Step Transmission with Integrated Factory Cab MF = Mechanical Shuttle, 2wd
MDT = Mechanical Shuttle, Dual Traction
SS = Shuttle Shift
T = Tow Tractor
W = Wide tread for Row Crop applications. (i.e., Tobacco)
DTC = Dual Traction 4wd, Cab Model
DTCCS = Dual Traction 4wd, Cab with Creep Speed
M Series
DT-1 = Dual Traction 4wd, ROPS model with IC/Shuttle Transmission (M7580/M9580)
DTL = Dual Traction 4wd, Low Profile (for orchards)
DTM = Dual Traction 4wd, MUDDER (for specialty, row crop and vegetable)
DTN = Dual Traction 4wd, Narrow (for vineyard/orchard tractor)
DTN-B = Dual Traction 4wd, Narrow wheel tread with Bi-Speed Turn
F = Two Wheel Drive
F-1 = (-1) = Larger two pump hydraulic system
FC = Two Wheel Drive Cab Model
F-CS = Two wheel drive with Creep Speed (Ag. tires or as Turf Special)
HC = High Clearance (2wd M7950 only)
HD = Hydraulic Shuttle, 4wd
HDC = Hydraulic Shuttle, 4wd, Cab
HDCCS = Hydraulic Shuttle, 4wd, Cab, Creep Speed
L = Low Profile
ML = Mechanical shuttle, Low profile
MDT = Mechanical shuttle, Dual traction 4wd
MDTL = Mechanical shuttle, Dual traction 4wd, Low profile
MF = Mechanical shuttle, Two wheel drive
OC = Orchard model
S = Synchro-Shuttle, 2wd
SD = Synchro-shuttle, 4wd
SCS = Synchro-Shuttle, 2wd, Creep Speed
SDN-B = Synchro-Shuttle, 4wd, Narrow with Bi-Speed Turn
SDNBC = Synchro-Shuttle, 4wd, Narrow with Bi-Speed turn, Cab model
SDNBF = Synchro-Shuttle, 4wd Narrow with Bi-Speed turn, Foldable mid-mounted ROPS
SU = Special Utility, 2wd
SU-R = Special Utility 2wd, Rigid ROPS
SU-F = Special Utility 2wd, Foldable ROPS SU-TF = Special Utility 2wd, Turf Special
SUD-R = Special Utility, 4wd, Rigid ROPS
SUD-F = Special Utility, 4wd, Foldable ROPS
SUMDT = Special Utility, Mechanical Shuttle, 4wd
SUDT = Special Utility, 4wd
W = Wide Row
H = 2WD, ROPS (Note: All H-Models are Std. Swing Shift 16F X 16R speeds)
HC = 2WD, CAB
HD = Swing Shift, 4WD, ROPS
HDC = Swing Shift, 4WD, CAB
DS = Dual speed, ROPS (Note: All Dual Speed models are 32F X 32R speeds)
DSC = Dual speed, CAB
SDSCC = Dual speed, CAB, cold weather w/high amp alternator and creep speed and second remote valve
SDSC = Swing Shift Dual Speed, CAB DSDF = Dual Speed, 4WD, ROPS
SDSL = Dual Speed, 4WD, Low Profile
M-Series Notes:
Suffix "1 models are the second generation "Wide Cab tractors. Cab is 5.7 inches wider than first models.
Suffix "2 models are factory equipped with 540 / 1000 RPM PTO kits. M95S and M105S:
The "S represents the model/tractor class in general is no specific meaning, however it can be applied to "Swing Shift as the base transmission on all "S models.
M50-Series 1983 - 1984 Cab was orange in color, air conditioning was optional.
2018 TowMaster T-12D T/A Flatbed Trailer (A55853)
2018 TowMaster...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A54756)
KNOW BEFORE YOU...
PALLET OF SCAFFOLDING (APPROX. 12 PC) (A52706)
PALLET OF...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A55788)
2018 Nissan Titan...
2017 Ford F-150 Pickup Truck (A55788)
2017 Ford F-150...
(49) 2" X 2" X 98" TUBING (A54756)
(49) 2" X 2" X 98"...
