Series or Parallel
   / Series or Parallel #1
DaveNay
Platinum Member
Waterman, DeKalb County, Illinois
John Deere 855 MFWD; Oliver 1850 Gas
I have a silly question..... I am adding a couple of 55 watt halogen lights to my tractor so that I can see behind me when plowing with my rear blade. I plan to connect the lights directly to the battery with an inline fuse and a toggle switch on the instrument panel. But do the lights get wired in series or parallel? I am sure that the answer should be obvious to me, but it's not. /forums/images/graemlins/confused.gif
Dave
   / Series or Parallel #2
You can run the wire from the switch to the first light and then to the next, or run a wire from the switch to each light. There is no difference as they are grounded to the tractor and have they,re own return to ground.
   / Series or Parallel #3
Davenay, I should reiterate, if you have plastic light bases and have two wires coming from the light fixture, use one for power and the other for ground, do not go from your switch to the first light and hook to one wire and then go to the other light with the other wire to the other light. Ground each one individually.
   / Series or Parallel #4
Parallel... sorta like the illustration.
Gnd------\/-\/
lites----> O O
12vdc----/\-/\
   / Series or Parallel #5
Parallel, as Jinman noted. rdbrumfield described parallel /forums/images/graemlins/grin.gif
   / Series or Parallel #6
Do yourself 2 favors.
#1) Run the lights to a relay so that the switch only powers the relay and the switch doesn't take the full load of the power draw.
#2) Get waterproof switches. A good waterproof switch will cost you about $8 and may last the life of the tractor. A cheap switch will cost you about $3 and you will probably replace it every year or two.
   / Series or Parallel #8
Dave,
If 9 amps strains your alternator, you might want to see how much light just one unit throws. 55 watts of halogen light is a lot if the floodlight lense can spread it wide enough.
John
   / Series or Parallel #9
Looks like you have the answer.
Just as an fyi... you can wire them in series but they would be kinda dim, each light would only get 6 volts.
   / Series or Parallel #10
Can someone recommend an online source for the waterproof switches and a relay. Where do people mount the relay? I've never used relays before, are they just a few bigger wires in and out to carry the load and a wire in and out to make a switch?
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2012 KOBELCO SK170-9 ACERA MARK 9 EXCAVATOR (A60429)
2012 KOBELCO...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
TANK MANIFOLD (A55745)
2025 MMS MS36C (A53317)
2025 MMS MS36C...
2013 Infiniti G37 Coupe (A59231)
2013 Infiniti G37...
