Setting Fence Posts Issue
   / Setting Fence Posts Issue #1
Furu
Platinum Member
I have been setting a LOT of farm/ranch wood fence posts (Round not 4x4) and ran into an issue yesterday that I have not previously had.
Most of my ground is hard clay and I do mean HARD and DRY clay.
In my one corner at the end of a 1600 foot run I dug two holes yesterday by hand as the hydraulic post driver could not get there and found water at 21 inches below grade. "Great" high water table in that location! What are my best options to keep post from rotting out?
Looked on line and found a sleeve that is designed to prevent rotting at grade but I thought I had heard of a sleeve that will protect the post all the way to the bottom of the hole.
This morning found the water had risen to 12 inches below grade so it is even worse than yesterday.
Does anyone have any knowledge of how to protect a post that is set in a high moisture ground condition. Most likely it is seasonal but I never knew this specific corner had such a high water table.
   / Setting Fence Posts Issue #2
I would bet that my posts are damp most of the year at 30" deep. They always seem to rot off near the surface though while being solid down deep.
   / Setting Fence Posts Issue #3
We've had a fair amount of rain lately and if I went and dug a post hole right now there is a good chance that it would have water in it. That doesn't mean your water table is that high though. You just have moisture in the ground that is converging on that hole because you removed soil and it will flow to the point of least resistance.
I would just sink the post, tamp it in good and not worry about it.
   / Setting Fence Posts Issue #4
Every wood post that has broken, was weak within the first 12 inches below the ground. The rest of the post in the ground was solid and a bear to remove. I have been wrapping replacement wood posts with plastic in that 12 inch zone to separate the wood from the earth. I'll let everyone know the results in 20 years.
   / Setting Fence Posts Issue #5
Where are you? Assuming that you do not have easy access to cypress or locust, I would choose either a marine grade pressure treated post UCB4 (or better), or creosote treated, or switch to a steel post, or pour a concrete pier and bolt a post to it.
There are vinyl sleeved wood posts that are said to protect against insects, but I have no experience with them. IIRC, they are not cheap.
Clay soils will always hold water against the post and that tends to make even normal pressure treated wood decay in a few years, at least around here. Hereabouts, old growth redwood tends to resist rot for 100+ years. Newer redwood, not so much. After losing a bunch of pressure treated "ground contact rated" fence posts, I have gone to treating my UCB4B rated posts with 17% copper naphthenate (2% copper) by brushing it on until it is no longer absorbed.
Good luck,
Peter
   / Setting Fence Posts Issue #6
Furu, don't worry about the wood below the water level rotting, it won't. Wood will rot in the first 4" of ground where there is ready access to oxygen for the rot/fungi to breathe. In 30 years when the fence is replaced you will find the base of the post sound with a "collar" of rotted wood at the ground level point.
I recommend you use naturally ground durable species of timber, treated wood or steel(galvanised, as clay is corosssive).
   / Setting Fence Posts Issue #7
Wood rots because the living organisms in the dirt have the proper condition to eat the wood. Water and air. Wood submerged in water 100% of the time does not rot. Same with wood in the ground that air cannot get to, does not rot.
The problem with wood posts in the ground happens at ground level. The biggest reason is when people fill in around the post with soil, the ground settles over the years because it's loose soil, and you get an area that holds water. Filling with dirt is probably the biggest reason wood posts rot.
If you fill with concrete, the post will be stronger, but even more important, you build up around the post with the concrete to create a crown so the water will flow away from the post. If water cannot sit next to the post, the post will not rot.
Early on, I filled some of my wood posts with dirt and compacted it with the a shovel handle in lifts. I felt that I did a pretty good job. I even built up the dirt so water would flow away from the post. In less then a year, the dirt had settled, or washed away to the point that water was sitting at the base of the post. In my opinion, it is impossible to keep water away from a post with dirt.
Recently I've been building a new fence and removing my old fence. I'm using better wire, more wood posts and trying to make it the best fence possible. I use my front loader with a chain to pull the wood posts out. The ones in dirt come out super easy. The tractor is at idle and it doesn't take any effort at all. I'd say they come out as easy as T posts. The posts set in concrete need more RPM's to pull out, and the front tires compress noticeably before the post breaks free. There is a night and day difference in how much harder it is to pull a post set in concrete.
   / Setting Fence Posts Issue #8
Have used a lot of post setting foam. Works well in wet areas. You would just need to pump out most of the water when setting the post.
   / Setting Fence Posts Issue #9
Good luck,
Peter
Not sure my clay will hold water most of the time. Not exactly moist here most of the time and this was a dry winter. Very low snow fall. This is the first time I have found any clay that was not hard and dry. This area (corner) obviously is different. What I did not mention is that I found a gravel and sandy clay combination at 20 inches like drillers find where they hit water when drilling. As I said the next morning the water was at 12 inches and the following day I had water at grade. The soil in the area is pretty much dry (slightly moist maybe)at the surface and for the first 12 inches of digging. For the water to rise to grade there must be enough hydraulic pressure to force the water up that much. It is almost like I now have a small spring.
2016 KENWORTH T680 SLEEPER (A43005)
2016 KENWORTH T680...
Super Material Lift MH1000 (A48561)
Super Material...
More info coming soon! (A44572)
More info coming...
2023 HELI CPYD25C FORKLIFT (A47001)
2023 HELI CPYD25C...
New Wolverine Skid Steer Pallet Forks Hydraulic Adjustable (A48289)
New Wolverine Skid...
2021 Dosko 13-21T-13H 4in Brush Chipper (A45336)
2021 Dosko...
