   / Share Pics of People Hauling or Towing Something Wrong #22,711
There are hooks with carabiner style spring loaded closed ends which will not unhook during momentary slack in the tie strap. I wish I could find some for reasonable prices. Or a carabiner honestly rated 2000 pounds or more.
Common practice in sailing, for clip fasteners (e.g. carabiners, shackles, etc.) that one can't afford to have come un-clipped, is to just tie a loop of dyneema (e.g. Amsteel Blue) line as a back-up to the carbiner or shackke. That way, if it manages to come un-clipped, you still have the loop of line holding the rig together.
It only takes an arm's length of line or less, to back up a hook or shackle, assuming you're not worried about backing up the webbed length of the strap itself.
Helps to avoid having to do this, alone at sea! :D
   / Share Pics of People Hauling or Towing Something Wrong #22,712
Well color me curious... if you don't use straps, what do you use? Chains? Ropes? Faith?
Ropes, tied with the same knot I learned to use when tieing down apple crates.
   / Share Pics of People Hauling or Towing Something Wrong #22,713
Places that sell tree climbing gear will have biners rated at 5000 or so. Like this:
My local Vermeer dealer also sells climbing gear.
My farm store sells biners like this too. 3K, 5K, 6K ratings.
   / Share Pics of People Hauling or Towing Something Wrong #22,714
She is one brave gal. Even going alone!
   / Share Pics of People Hauling or Towing Something Wrong #22,715
Like these 2k and 6k straps with locking hooks?
Yup, those type of hooks are what you should be using if it has a suspension. They stay on, even if some slack develops.
   / Share Pics of People Hauling or Towing Something Wrong #22,716
Also using a long tiedown with the fronts angled to the rear and the rears to the front, the shallow angle will dramatically reduce the amount of slack suspension movement will generate.
   / Share Pics of People Hauling or Towing Something Wrong #22,717
   / Share Pics of People Hauling or Towing Something Wrong #22,719
I’ve said it before, gravity natures tie down. Of course if the momentum overcomes the static coefficient of friction problems develop.
   / Share Pics of People Hauling or Towing Something Wrong #22,720
Aside from the excessive overhang, he appears to be using blue-tooth tie downs.
Yeah, he also didn't have any lights on the trailer, and was going more than the 20 mph the SMV would indicate!
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2014 K-Z RV STONERIDGE 38FT RV TRAILER (A58214)
2014 K-Z RV...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A56857)
2025 GIYI GY-ZWB...
