Sharpened blades on mower deck
   / Sharpened blades on mower deck #21
Rented a torque wrench to do a big diesel overhaul It was 4 feet long took two men to torque things to 450 and then 650 lb .
   / Sharpened blades on mower deck #22
just look at the free-body diagram for a blade on a spindle. Blade bolts are self tightening. Hit something and they really get snug.
   / Sharpened blades on mower deck #23
I've read elsewhere in OTT that the WSM for Kubota decks seem to recommend 450lbs/ft for most of the MMM decks. My 1/2" Dewalt pneumatic impact will do 650ft/lbs. I haven't found a 3/8" that will go above 350. If possible, I think I'll be blocking my blades with 2x4 and leaving mine on to sharpen. Just seems nearly impossible to get the torque right otherwise.
JK22,
PLEASE recheck those torque specs ! ! ! My SM for the 54" MMM has a spec of 72.3 to 86.8 ft lbs. I tighten mine to 75 ft lbs. Have had no problems with it in nearly 500 hrs of use.
Dave
   / Sharpened blades on mower deck #24
JK22,
Dave
Please note I previously stated my prior post was incorrect. I can't edit my post--- but I did do a new post above. I regurgitated bad information.
   / Sharpened blades on mower deck #25
Anyone with the initials J/K can't be all bad.... we forgive you your transgressions .... :)
   / Sharpened blades on mower deck #27
I purchased a Harbor Freight fancy 1000lb/ft impact to try and get my blades off my finish mower. I will certainly be putting some anti seize on the bolts when putting back on.. and torquing to proper value with hand torque wrench.
I remember as a kid we had a gear reducing truck lug tool. It had a 5' handle and a big head with gears. It was easy to move the lever, but was slow going.
   / Sharpened blades on mower deck #28
First time I've seen the words "fancy" and "harbor freight" in the same sentence.
   / Sharpened blades on mower deck #29
[ TL;DR - if you wet threads before torquing, don't torque as hard ]
Just a quick FYI, if you oil/grease/anti-seize threads before torquing:
With less friction (wet threads), the bolt will stretch more before a
torque wench will click. Because friction is such a big factor in bolt torque, it is important to know the
difference between applying torque to a dry bolt and a wet bolt. Using oil, anti-seize or other types of
thread lubricant is a common practice, but an understanding that wet threads require less torque than dry
threads because of friction is very important.​
(From this link, which was the first thing that popped up from a google search for "wet torque vs dry torque".)
   / Sharpened blades on mower deck #30
I'm a firm believer in a torque wrench. I torque mine to 80 ft/lb
International 4700 Vibra Tiller (A51039)
International 4700...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
UNUSED CFG Industrial MX50R Mini Excavator (A47384)
UNUSED CFG...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
Kubota SVL 95-2s 14009 SKID STEER (A50322)
Kubota SVL 95-2s...
