shear bolt blues, need advice
   / shear bolt blues, need advice #31
The 2 seconds is what I consider an overall time. i try to make my move smoothly.. and take about 1.5 seconds or so to be gein engaging.. and then as soon as the first movement starts, use the other hald second to finish engaging so as to not wear the pto clutch.. In any case.. you have the same 'new' style trans setup that I do. My 1975 5000 has the old style.. no guide.. easer to move.. etc.
Soundguy
   / shear bolt blues, need advice #32
Wow you learn something every day thanks alot. I have always shuddered when engaging the pto. Most all of the other tractors Ive driven you used the half clutch method.
   / shear bolt blues, need advice #33
double checked the "jensales" manual last night, nothing about feathering,just says to idle down before engaging. But I will give it a try next time I get on the tractor.. Im hoping to use the boat instead this weekend but you never know.
   / shear bolt blues, need advice #34
If you have a fax number that you would like to PM me with.. I'd be happy to copy the page out of my 5610/6610/7610 manual that speaks about feathering the independent pto to the engaged position.
If no fax... a snail mail address will be fine.. I can xerox a copy off and stuff it in an envelope.. and you can just add it tot he jensales manual...
have a good one!
Soundguy
   / shear bolt blues, need advice #35
Hey Pat,
How long does it take to shred an acre using the boat?
   / shear bolt blues, need advice #36
That's what? an 8" cut? (grin)
But if it starts raining.. you are -fine-!!
Soundguy
   / shear bolt blues, need advice #37
Thanks soundguy, I tried every way I could to feather in the PTO this weekend but it still seems there is no "slipping" it in like with a clutch. Its on or off. I dont know if its the same as on your tractors or not. When the motor is off the pto is free turning, they mention in the book that this is too make hook up easier on ptp splines. When the tractor is running the pto shaft is locked tight. Possibly the pto break is not letting go until all of the feathering space is used up. And to 960: my jet drive boat has a 12" intake grate so it would take a while. but I have been known to shred a trail of sea grass through the flats. but when the grate is clogged you have to dive under the boat to clear it.:) :)
   / shear bolt blues, need advice #38
I think with more use feathering, your pto clutch will smooth up.
When I first started using mine.. there was no noticeable slip area.. but now I can feel it.
I did some checking, and your independent pto arangement is virtually identical to mine, per the CNH dealer.. As a matter of fact.. most of the late model 8x2 trannies are virtually identical in function..e tc.
Perhaps with more use it will free up some. If yours feels anything like mine.. .. it takes a significant amount of pressure to shift mine... thus making it hard to feather without it jambing all the way over when it finally gives.
Have fun!
Soundguy
   / shear bolt blues, need advice #39
"Anyone with an HST care to drop in and give info about your pto clutch setup.. list makes and model, and size.. etc. any other helpfull info you might have too."
Kioti CK30, 30 HP, the PTO is solidly engaged with a lever. Ahead of the HST there is an engine clutch with a pedal. I idle the engine, disengage engine clutch, throw PTO lever to ON, slowly engage the clutch (slowly turing PTO), and then increase RPMS to PTO540. Blades spinning full speed and the HST allows variable speed and direction without clutching or slowing blades.
I love my slip clutch.
   / shear bolt blues, need advice #40
Your system works like a 2 stage clutch setup.. in that you can clutch engine and pto by hitting the clutch, or just stop drivetrain momentum by using HST pedals.
Soundguy
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A53424)
Year: 2017 Make...
2014 Peterbilt 337 Service Truck (A53422)
2014 Peterbilt 337...
2007 Hyundai Sonata GLS Sedan (A54815)
2007 Hyundai...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2014 FREIGHTLINER M2106 BUCKET TRUCK (A51406)
2014 FREIGHTLINER...
66'' root grapple (A53421)
66'' root grapple...
