Sheave block mechanical advantage?
   / Sheave block mechanical advantage? #1
Billy Bee
Lowell Michigan
New Holland TC 33, John Deere 3020
I am no physics major, I know a block and tackle increases pulling power, but with just one pulley, like on a sheave block does it increase mechanical advantage, or is it just 1 to 1. I want to persuade some trees to fall were I want them to.
Thanks,
Bill
   / Sheave block mechanical advantage? #2
Moving/movable pulleys increase mechanical advantage. Fixed pulleys only change direction.
Doug in SW IA
Kinda what i figured. I don't need a lot of persuasion, so it will work. Changing direction is what I want to do, so I can pull one direction away from where I want the tree to fall.
   / Sheave block mechanical advantage? #4
Yep the pulley has to move to create advantage. With just one pulley the winch line will need to go from the winch to the object you want to move and back to an anchor point at the winch. The pulley would be at the object that you want to move. This is a simple 2:1 system.
This is roughly twice the force and half the winch speed.
   / Sheave block mechanical advantage? #5
Maybe, I don't understand.
But . . .
With one pulley, now the rope is doubled and you are gaining a 1-2 advantage (If I said that right) and the one loose end is attached to some fixed point, other then the pulling point.
So regardless of what the pulley is doing, you measure advantage as to how much line you are pulling in relation to how much your load moves.
My Dad taught me that when I was around five. My toys were a couple of clothes line pulleys and some rope.
   / Sheave block mechanical advantage? #6
I don't quite understand your last sentence there IT, but with one pulley attached to the tree, the winch line out - thru the pulley and back and attached to the winch or an attachment point on the winch vehicle - you have doubled your winch pull( example - 5000# to 10,000#) and cut the winch cable retrieval speed in half(basically).
   / Sheave block mechanical advantage? #7
Pulley attached to Tree.
One free end to, let's say a (large) tree in the direction you are pulling.
And the other end to the tractor or winch.
You are now pulling twice as much line for the movement of the target, effectively giving you a 2-1 advantage.
So thinking, about it, if you had a Winch, you could attach (the other free end) to the vehicle with the winch, but not without a winch.
   / Sheave block mechanical advantage? #8
A pulley has to be attached to the load, to be considered a mechanical advantage. If the pulley is attached to the anchor, it's just a change of direction.
Mechanical advantage are always in odd numbers, due to having to have an anchor point. Example, 3:1, 5:1 etc.
   / Sheave block mechanical advantage? #9
If you are not at the least bit certain what you are reading on this post, go search block and tackle uses and set ups. Just a short note. As indicated in other posts, you hang the block from the tree. You run the the pull or winch line from the pulling source through the bock and then back to the winch or a deadman in close proximity. You double your power.
Now, if you have that line quartered on the block or at any angle,you are decreasing your power.
Say you want to have your pulling device on the side someplace you need to use a directional block that has no true pulling power but merely gives you the opportunity to pull from another place to take you presumably away from danger. So in that instance, you will have a power block AND a directional block.
You "might" want to hang your tree block in some way to hopefully minimize the possibility of damaging it when the tree falls. Best not to hang the block tight but hang a long chain or rope from the the tree, attach your block there. That way when the ship hits the fan, you block will most likely escape abuse.
Pulling a tree over is a tricky deal for backyard experimentation. Often pulling is not necessary. TENSION is the tool to persuade a stubborn one, and pulling one over 180 degrees is a challenge to do with out extreme danger to the inexperienced.
play safe.
   / Sheave block mechanical advantage? #10
I am having a cheap 2500 # portable electric winch delivered today. I would like to pick up some free concrete steps (Five High) and drag them onto a trailer.
Are most cheap winches rated for what the capstan can pull or what the winch frame can withstand? Applying mechanical advantage in multiples could easily exceed the strength of the winch castings, I would think.
And yes, I agree. getting some trees down can be EXTREMELY tricky and dangerous. Browse Youtube for Many examples of this gone wrong.
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
2015 Blue Bird 48 passenger school bus (A47477)
2015 Blue Bird 48...
Woods BB72 6' 3pt. Rotary Mower (A50775)
Woods BB72 6' 3pt...
WB 32in Excavator Digging Tooth Bucket (A55787)
WB 32in Excavator...
2016 Dodge Charger SRT Hellcat Sedan (A53424)
2016 Dodge Charger...
70pc 12ft.x 3ft. White Metal Roof Panels (A53424)
70pc 12ft.x 3ft...
