SHHHHHHHHHHHHHHHHHHHHHHHH
   / SHHHHHHHHHHHHHHHHHHHHHHHH #91
Thats true, My 2210 with the 200cx has sloped arms . I'm not sure how wide the bucket is though.
Jim
   / SHHHHHHHHHHHHHHHHHHHHHHHH #92
Hmmm, Another good thing on the configurator (sp?) is that there are now brush guards available for the warning lights! I'd like to get those for my 2210.
   / SHHHHHHHHHHHHHHHHHHHHHHHH #93
Standard Features
2305 4-Wheel Drive Tractor
ENGINE:
Yanmar 3 Cylinder Liquid Cooled Diesel Engine
Horsepower @ 3000 RPM: Gross 24.0 (17.9 kW)* Net 23.5 (17.5 kW)*
PTO 18 (13.4 kW) HST*
*Manufacturer's Est.
68 Cu. In. Displacement (1.115 L)
Indirect Fuel Injection
Auto Bleed Fuel System
Glow Plug Cold Starting Aid
Anti-Freeze
Dry Type Air Cleaner With Safety Element
Fully Enclosed Engine and Muffler With Horizontal Exhaust
5.5 Gallon Fuel Tank Capacity (21 L)
Hand Throttle
Key Engine Shut Off
TRANSMISSION:
Hydrostatic Transmission:Infinitely Variable - 2 Speed Transaxle
2-Pedal Foot Operated Speed and Direction Control
Differential Lock
FRONT/REAR AXLE:
Flanged Rear Axle
Spur Gear Final Drive
4WD
STEERING AND BRAKES:
Hydrostatic Power Steering
Wheel Brakes
Park Brake
Wet Disk Brakes
HYDRAULICS:
Open Center Hydraulic System
Hydraulic Pump - Total Flow 5.2 GPM (19.7 L/min) with Filter
Working Pressure (1987 PSI)
Dual Mid SCV Standard
PTO:
Mid PTO Standard Equipment
Independent Mid and Rear PTO
540-RPM Rear PTO
Hydraulic PTO Clutch
PTO Brake
Separate or Simultaneous Operation of Mid and Rear PTO
Flip Up PTO Shield
ROCKSHAFT, 3-PT. HITCH, AND DRAWBAR:
Rockshaft Limited Category 1, 3-Pt. Hitch
Rate of Drop/Stop Valve
Drawbar
INSTRUMENTATION:
Electric Fuel Gauge
Tachometer/Hour Meter
Oil Pressure Indicator Light
Coolant Temperature Light
Alternator Indicator Light
Flashing Warning Light Indicator
ELECTRICAL:
12-Volt Electrical System
Wet Battery With 500 Cold Cranking Amps
20 Amp Alternator
Key Ignition Starter With Neutral Start Switch
LIGHTS:
Two Front Halogen Head Lights
Two Flashing Warning Lights
One Tail Light
OPERATOR PROTECTIVE STRUCTURE:
Fixed ROPS (Roll-Over Protective Structure)
Deluxe Cushion Seat With Seat Belt
Operator Presence System
MISCELLANEOUS:
SMV Emblem
Front Weight Bracket
Tilt-Up Hood
Cupholder - Left Console
Mower Deck Height Adjustment
BASE MACHINE (4WD):
Engage on the go 4WD
TIRES
Two - Steel Wheels With 26x12-12 4PR (R4) Rear Industrial Tires
Two - Steel Wheels With 18x8.50-10 4PR (R4) Front Industrial Tires
-or-
Two - Steel Wheels With 18X8.50-10 4PR (R3) Front Turf Tire
Two - Steel Wheels With 26X12-12 4PR (R3) Rear Turf Tire
   / SHHHHHHHHHHHHHHHHHHHHHHHH #95
The brochure says is uses 1.6 gallons/hours at full load. This seems high to me.
   / SHHHHHHHHHHHHHHHHHHHHHHHH #96
Full load is very heavily loaded, but that still seems high....
   / SHHHHHHHHHHHHHHHHHHHHHHHH #97
When looking at this link to the 2305 info., I can't help but think the picture of the front in the "attachments for field ..." section looks like the model number is 2320. Plus the front lights look different than the 2305. Is this a peek of the new CUT series?
   / SHHHHHHHHHHHHHHHHHHHHHHHH #98
Good catch. I think your right. Looks like a 2320 to me. Also look for a reference to the 2000 Twenty Series under the iMatch Quick Hitch section. I think we can safely say that a they are coming, can't wait to see them. Personally I hope the adapt a mower hook-up system common to the 2305, the one they use now on those units is awkward. When they come out, I think Deere will have a really nice, complete line-up.
   / SHHHHHHHHHHHHHHHHHHHHHHHH #99
Look on page 17 rear working lights , look below photo shown on 3000 TWENTY series.
   / SHHHHHHHHHHHHHHHHHHHHHHHH #100
I just got a quote from my dealer in PA.
2305, 200cx FEL, 62c MMM, hood guard, ballast box....
$14,200. Claimed to be available Aug. 19th. This is, however, without the independent MMM lift. I'm told that it will be available in the fall.
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51573)
IMPORTANT PLEASE...
2023 LMC M30018 LOT NUMBER 207 (A53084)
2023 LMC M30018...
2024 New Holland T8.410 MFWD Tractor (A53472)
2024 New Holland...
New Wolverine Skid Steer Root Rake Bucket Attachment 31'' (A53002)
New Wolverine Skid...
2021 Big Tex Trailer Trailer, VIN # 16V3F4826M6084230 (A51572)
2021 Big Tex...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
