Shibaura 1540b 3 point won’t lift
   / Shibaura 1540b 3 point won’t lift #1
Neil1982
2008 Massey Ferguson GC2310
I just purchased a Shibaura 1540b and it was having hydraulic issues caused be a clogged screen. After draining the oil and cleaning the screen the loader works perfectly but the 3 point doesn’t want to lift. It will only lift while cold or if I shut down the tractor for a few min but sometime that doesn’t even work.
Any suggestions on what it could be?
I’m thinking piston seals….
   / Shibaura 1540b 3 point won’t lift #2
You may get answers if posted in the Ford compact section or the Shibaura section. This section is for easy hydraulic questions. Not a hard one like this since it's a Gray Market imported machine from Japan built to JIS standards and not SAE.
   / Shibaura 1540b 3 point won’t lift #3
Knob under in front of seat. Take out and check o ring.
   / Shibaura 1540b 3 point won’t lift #4
IS this a D1540 or a SD1540 or a SP1540 ? You are missing the first 2 letters for the series.
Sd1540b
   / Shibaura 1540b 3 point won’t lift #6
Nice. :)
That is one manual I do have and can share here. :)
You can look at the parts diagram of the hydraulics and see if something isn't right.
  • SHIBAURA SD1500 SD1540B.pdf
2023 54ft Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54ft Hooklift...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A53421)
2017 JLG Skytrak...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2019 VOLVO VNR TANDEM AXLE MID ROOF TRUCK (A56129)
2019 VOLVO VNR...
White Single Stall Portable Toilet (A55758)
White Single Stall...
Golf Cart (A55853)
Golf Cart (A55853)
