Shop Air Compressor set up questions?
   / Shop Air Compressor set up questions? #11
My Compressor is in a heated (just above freezing) second story storage room of my barn and feeds three other buildings as much as a couple hundred feet away. I had issues with condensate freezing coming down from the compressor through an unheated area, but never underground.
I love having air, without the noise. I have a dryer, but never use it. The compressor cycles but how and when do you turn the dryer on and off? I might turn it on, if I wanted to do a bunch of painting.
   / Shop Air Compressor set up questions? #12
Yeah, that's what I'm thinking he'll get.
   / Shop Air Compressor set up questions? #13
I put a heated cord on the troublesome spot, where I have a ball valve and gauge, but mice quickly chewed off the cord! Looked more like it had been cut off with sidecutters!
   / Shop Air Compressor set up questions? #14
I just assumed the closet would be heated since he's storing perishables in there?? Maybe I thought too deep into it.... :)
Brain storming here. So he has a heated closet, thus a heated compressor, full of heated air. So then the air line leaves the heated shop and runs the 70ft thru whatever system he creates throughout the cold shop. Won't the air condense more moisture as it cools in the delivery system?
Amusing that he has 25' of hose coiled on the floor before the water separator, a 5 micron filter should collect most of the remaining moisture. That's how mine works. If he needs dryer air, a point of use, decant dryer would be about the most economical. Or an evaporator.
https://www.northerntool.com/shop/t...MIuOa574b01wIVF1cNCh3HBQFWEAQYBCABEgLRzvD_BwE
   / Shop Air Compressor set up questions? #15
After reading part of this thread I opened my cheapo bleed drain valve and nothing came out. I unscrewed it after the pressure was almost out of the tank and got a half gallon of water.
I put an elbow on, run 6 feet of 1/4" copper line to a valve then ran it directly through a drilled hole in the exterior wall. Now I just can reach up now and then and blow the water out. Works great and I don't have to run the comp that much, but a woof every month should do it.
   / Shop Air Compressor set up questions? #16
To help with the noise build two walls that do not touch. Insulate both. If you want to save a bit of money then use 2 x 6 top and bottom plates and use 2 x4 studs. One row of studs on the inside of the plate and one row of studs on the outside of the plate. The studs alternate on spacing. This prevents sound traveling through the studs since they do not go thru the entire wall thickness. A kerf cut (running length wise) most of the way thru the 2x6 bottom and top plate will help also. Once again your providing a gap thats harder for the sound to travel thru. Use sound board or if you need use celotex ceiling tiles (since they are made to absorb sound and are easy to find and buy) over the studs and then apply the sheetrock or wafer board over that. This provides a break between the studs and the cover sheets and provides another layer of sound barrier or absorption. Even a layer of foam insulation instead between the studs and wall covering will help quite a bit. A 2nd layer of celotex on the inside of the storage would help even more. Be sure to cover the exterior walls as well if you can on the inside of the closet. Caulk the wall at the floor to help prevent sound traveling under ( not kidding ) They even make caulk for this but its probably not worth messing with. Install your door just like you would a exterior door on your home. Expanding foam or insulation between the jambs and studs. Foam weather strip around the door stops. And a snug fitting threshold with caulk underneath it. Apply a layer of celotex to the the inside of the door also. It adds up to a really nice sound booth at a very moderate price. Especially if you find some used /stained celotex tiles.
   / Shop Air Compressor set up questions? #17
I'm more traditional, and would go with 3/4" black iron, with a drip leg near the compressor and angled slightly upwards, with a T every 10 feet pointed up. I would bypass the regulator and put full tank pressure into the pipe, then regulate and filter it at the source if you are doing something like painting. A 60 gallon compressor is high capacity, and you need a way to get a lot of air out fast. A 3/8" line to a die grinder would work fine, but be totally inadequate for a sand blasting cabinet. Even my 6" air orbital sander really needs a 1/2" line, and not a very long one, to get enough air.
   / Shop Air Compressor set up questions? #18
JMO, but I would not store flammables in the same closed up room with an electric start motor.
Something starts leaking , the motor starts, sparks, etc, and things may not turn out well.
   / Shop Air Compressor set up questions? #19
I store all my paint spray cans and regular cans in there, with the compressor. Never had one leak, but a spark likely wouldn't set that off. It's not like I store gasoline in there. I have an outside locker for that.
I can't be too careful as we have zero insurance, but the paint in the compressor room doesn't concern me.
   / Shop Air Compressor set up questions? #20
We plumbed our shop or rather are plumbing it with 3/4 steel pipe a bit at a time.
The local firehouse re plumbed their shop with what looks like PEX but not sure.
The fittings looked different so it may be different than home depot parts.
For sound your noise comes from a few places so addressing things like remote mounting the intake and possible sound barrier arround the pump.
Our champion is inside in the corner and with a 1700 rpm motor it has huge motor pulley so it is a loud one and a steel building does not help.
It does have an automatic tank drain that kicks every time the compressor stops as it uses the unloader to operate.
You should look at something similar for yours.
1998 BOMAG BW172D-2 SMOOTH DRUM ROLLER (A52707)
1998 BOMAG...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55315)
PENDING SELLER...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
