Should I Regret Buying A Kioti?
   / Should I Regret Buying A Kioti? #11
If the alternator is bad it should be covered. I was just venting that the dealer isn't doing these things for you.
Like you said, I'll bet no one would accept this treatment if it happened on their three month old car.
   / Should I Regret Buying A Kioti? #12
Agree with both responses except the voltage number. The actual voltage will depend upon the rpm being over idle, like 1000-1500 min to get the alternator output up to regulation voltage and then increase at a very slow rate, and the charge level of the battery. The alternator has an output current limit and if that is exceeded it limits the current which limits the voltage across the batt terms. Once the charge is near max, the alternator voltage regulator will set the output voltage near the max regulated value with the reduced current.....the regulator has a wattage rating and will contain the volts and amps to remain in that envelope.
I am currently accustomed to alternators on marine outboard engines but they use the same batteries as other things and the "rules of engagement" should apply. The number there is 14.5v max for a regulated power source and 16+ for unregulated.
Wet cell batteries use a mixture of Sulphuric Acid and water to accomplish the chemical transition with the lead plates as a function of power moving in or out. The Sulphuric acid remains in the battery normally, but the water boils out at a lower temperature and since they are dissolved in solution carries some acid (H2SO4) with it which is extremely corrosive.
The charging rate determines the amount of boiling and the temperature of the battery. High charging rates generate visible bubbles which is the water boiling out. The higher the charging rate the more bubbles, the higher evaporation rate which lowers the water level in the battery. On older style non "maint-free" batteries there are caps on the battery (such as what I see in your picture) which can be removed and the process monitored, including the water level.
On your battery with the observed overflow, I would expect that the solution level would be well below the "full" ring and possibly low enough to expose the tops of the plates.
A few checks could tell you what you want to know, as listed above but shooting from the hip, I'd say that your regulator in your alternator isn't regulating and that is something that your dealer is obligated to repair/replace.
The other possibility is a defective battery with a shorted cell, very unlikely at that age of usage, which causes the alternator with proper regulation to continue to pump current into the battery in an attempt to get the terminal voltage up to the point where the alternator shuts down the current. A load test of a fully charged battery could answer this question. First off would be the terminal voltage. If the battery has sufficient water to reach the full rings and has been charged, but has been off the charger for at least 12 hours the terminal voltage should stabilize at some value within the 12-13 volt range.
With that you connect the battery to a load tester and crank up the current to 200 amperes. A good battery will hold approx 11v at the terminals. Most battery testers have 2 meters (current and voltage) with green, yellow, and red scales. The scales tell you what to expect for the applied load. Wally World has them in the auto service bay.
Once you have your battery tested, if it passes and hasn't been "killed" you are ready to approach your dealer to fix his tractor's regulating system and while he's at it he can add cleaning up the collateral damage to the effort.
New batteries just don't do what you are seeing for no reason and on a new battery, usually it's not the batteries fault.
HTH,
Mark
   / Should I Regret Buying A Kioti? #13
Clean-up with Backing soda and water. Replace battery and start up let run 5 minutes and check voltage while running. If still charging at 13.5 and above your VR is stuck and you need a new alternator.
Is the Kioti voltage regulator internal to the alternator or external. (Does anybody use an external VR now a days?)
   / Should I Regret Buying A Kioti? #14
Yes it is. And not that I know of.Butt I could and probably am wrong.
   / Should I Regret Buying A Kioti? #15
rt.
HTH,
Mark
Ordinarily I'd agree but from what i've seen and heard, these batteries are not sealed well at all. After I fixed my external damage and put in a better battery, i have never confronted the problem again and it's been a year out.
   / Should I Regret Buying A Kioti? #16
My neighbor by my property as well as friends told me the dealer needs to come and get the tractor and make everything right.
Do you think John Deere or Kubota would have taken care of me had I bought one of them?
I would have informed the Kioti dealer of the leak and the battery tray and paint damage the leak caused and asked them to replace the battery, battery tray and repaint the frame AT TIME OF FIRST DEALER SERVICE. After all, the alternator needs to be checked out.
I do not know how far you are from the dealer, but transporting a tractor is very expensive and transportation is not covered as part of warranty repairs.
If you, rather than the dealer, are going to service the tractor I think the dealer should provide a new battery tray, paint and refund you the cost of a replacement Kioti battery.
Tractors are workers. Don't let a minor paint glitch get under your skin. The dust will cover the offending paint repair again, soon enough.
Kubota is equally "tough" on warranty repairs based on my purchase of two new Kubota tractors.
The problem with threads in this category is that we do not get to hear from the other side, usually, and there is always another side.
I feel your thread title is immoderate and inflammatory. A better title would be "Kioti Battery Leak And Associated Corrosion."
   / Should I Regret Buying A Kioti? #17
I like Interstate myself
   / Should I Regret Buying A Kioti? #18
   / Should I Regret Buying A Kioti? #19
   / Should I Regret Buying A Kioti? #20
I remember when I bought the tractor how the dealer told me about Kioti having one of the best "bumper to Bumper" warranties out there
....It sounds like he's telling you "Ahh yeah, about that, wish I could help, but see your tractor has no bumpers, so there's really nothing I can do. If only you'd bought the optional bumper package.."
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
Cummins DGCB 60 kW Standby Diesel Generator (A56857)
Cummins DGCB 60 kW...
Hydraulic Hose and Fitting Replacement Pack (New/Unused) Est Retail Value $2,650 (A59225)
Hydraulic Hose and...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
2010 Cadillac SRX SUV (A56859)
2010 Cadillac SRX...
