Should Kubota L2800 HST 4x4 pull 6' Finish Mower?
   / Should Kubota L2800 HST 4x4 pull 6' Finish Mower? #11
Re: Should Kubota L2800 HST 4x4 pull 6\' Finish Mower?
I pull a Woods 6' RFM with an old Kubota L245.
It is listed at 22 pto hp. I usually mow in 5th gear (1 hi).
I believe I could cover ground faster with more pto hp but it does a pretty good job.
I would think that your newer tractor would do better than my old one?
There may be a problem with the tractor or maybe the finish mower?
   / Should Kubota L2800 HST 4x4 pull 6' Finish Mower? #12
Before getting my L3130, I used (and still have) a massey 20 HP, and it did fine with a 6' finish mower and 5' rotary mower.
   / Should Kubota L2800 HST 4x4 pull 6' Finish Mower? #13
I'm running a 5' mower behind a Deere 790. I really need a 6 footer...the tractor has plenty of power for it...as your L2800 does.
I think your tractor has a problem. If your dealer has a dynometer..might be worth while.
   / Should Kubota L2800 HST 4x4 pull 6' Finish Mower? #14
Roy i am pulling a 5FT behind my B2400 with no problem, you should be able to pull a 6Ft with ease.
   / Should Kubota L2800 HST 4x4 pull 6' Finish Mower? #15
I recently found a good deal on a 72" Land Pride but was concerned my TC24 would have problems running it. I bought it anyway since it was at a price I didn't want to pass up. I've mowed with it three times and the TC24 (18.5hp pto) handled it just fine. My land is flat and I don't let it get very long but it sounded similar to yours, around 4"-5" not super lush. I'm in low with the pedal to the floor. Works great.
   / Should Kubota L2800 HST 4x4 pull 6' Finish Mower? #16
Like others, I pull a 5' Befco behind my B2400 (18.5 pto hp) on rolling/hilly terrain without any problems. I think it would probably handle a 6' easily as yours should. You have to keep the engine speed up about 2200 rpm or so (see mark on rpm gauge) with a hydostatic to get the 540 pto rpm needed for the mower to cut well and use the pedal to control the ground speed. It shouldn't be a problem in Low and Medium although flat out in High might be asking a bit much. If you can't do that, there's something wrong somewhere, either with the tractor or the mower.
   / Should Kubota L2800 HST 4x4 pull 6' Finish Mower? #17
I pulled a 4' brush hog with my B7500hst (PTO only 16HP). Cut down everything I asked without much trouble at all.
Just my opinion - you might be alot happier with more horses, I am. A good dealer is worth his weight. I have a great one.
Alexander Equipment, Alexander, NY.
   / Should Kubota L2800 HST 4x4 pull 6' Finish Mower? #18
I have this combination. 6 ft Bush hog brand mower with rear discharge and a L2800 HST and my tractor has 8 hrs. I do cut at a higher rpm than when I use my M5700, but it pulls and cuts just fine. I usually cut at 2000 rpm and full forward in low range. This is still below the 540 rpm pto speed, so I don't think it hard on the machine. No problems. John
   / Should Kubota L2800 HST 4x4 pull 6' Finish Mower? #19
I'm wanting to find out the same information. I bought a Kubota B9200HST 4x4 a couplke months ago. So far all I've used is the loader but wanting to get a bushhog and finish mower. The tractor is rated at 22.5hp and it drops down to 16hp at the pto. What would be a good size mower to use with it. My land is a little hilly but I may use it to cut grass at other places and want something that I can handle hills without to much problem. After reading on here when I was trying to decide if I wanted to buy it. I went on Ebay and found a owners manual and shop manual but waiting for them on get here
   / Should Kubota L2800 HST 4x4 pull 6' Finish Mower? #20
I usede to pull a 6foot Land Pride RFM with my B7800 23 Pto and I have some hills. Try another brand of RFM. Cheaper than buying another tractor.
2016 Case CX160D Hydraulic Excavator (A51691)
2016 Case CX160D...
SPEECO SPLIT MASTER 15 TON PORTABLE WOOD SPLITTER (A51248)
SPEECO SPLIT...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
UNUSED ALLMETAL K0311-10' GALVALUME STEEL (A51248)
UNUSED ALLMETAL...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
