Shuttle shift F/R lever grinding
   / Shuttle shift F/R lever grinding #11
If the 3510 clutch assy is the same as my 4110, you could have snapped a pressure plate finger bolt - I have a couple of times over the years. When one snaps it won't release the clutch all the way with the other 2 fingers alone. It will release it just enough to grind it in & out of gear. I've had them snap out in the field and just started it in a low gear and knock it out of gear when you get to where you're going. I tried a clutch rebuilder in Nashville but they couldn't help me with a bolt, had to buy a reman. pressure plate. I've got it down to doing the clutch in one day if all goes smoothly, about a 6 to 8 hour job.
   / Shuttle shift F/R lever grinding #12
Is this an expensive repair something that I can do easily?
I just had this same problem on my 3510. Sent it to the dealer, and he is telling me it will be over $5000 for this repair. He is offering me a good tradeup to a new tractor. Giving it some thought.
   / Shuttle shift F/R lever grinding #13
Look for an independent tractor repair shop, and get a price for the labor only in writing.
Parts will cost the same no matter who does the actual work.
Dealers charge outrageous labor prices, and clutch replacement does not require a PHD.
   / Shuttle shift F/R lever grinding #14
Syncro replacement (which this is suspected to be) is slightly more involved.
I would want to see a breakdown on both quotes of parts vs labor.
Aaron Z
   / Shuttle shift F/R lever grinding #15
If the independent shop lays out $$ at the dealer for parts then marks them up the parts cost to the end user is not the same. The difference may or may not be offset by a more favorable labor rate.
Synchronizer replacement will require a partial transmission teardown, a fair bit more involved than a clutch job.
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
1959 DODGE D510 DUALLY FLATBED TRUCK (A60430)
1959 DODGE D510...
