Shuttle versus HST
   / Shuttle versus HST #81
Yeah, I think tractor size comes into play also. When you get up above 50HP the uses of the tractor tend to change.
I don't mean to offend anyone so am giving my disclaimer up front. No arguments desired. Just my opinion. Tractors in the CUT size and down are generally used for light chore work and small tasks. 90% of their life is spent doing tasks that they easily handle. Repetitive, low power requirement tasks. In that World HST shines.
Large CUT tractors and up into the Utility or AG class tractors are generally used for heavy FEL work, medium duty chore work (carrying two big bales) and larger occasional ground engagement tasks. 90% of their life is spent doing tasks that require their power and weight. Monotonous, grueling taks. In that World Shuttle shines.
Not a bad way of looking at it! For the most part the distance and the job at hand determine which machine I run. My DK40 is the largest HST I would really want and I would have probably got a shuttle if it wasn't for the other half wanting to use it for some of her things as well.
   / Shuttle versus HST #82
Familiarity/experience can also play a big part in one's preference or attitude. Until this year, my younger brother wouldn't even consider an HST or certainly not a cab and even sought out a synch shuttle CUT for use alongside his larger tractors. This summer, due to health issues, he has done a lot of work on my properties using my L5740HSTC and M8540HDS and the result is he wishes he had gotten an HST on the CUT really appreciates cabs and really sees the advantages of a hydraulic shuttle shift transmission.
Now he is certainly not going to be trading his geared machines off, but would have certainly gotten an HST on his CUT and understands why people like what they like. I don't see a cab in his future, but he now knows why people like them.
For many years, my ideal setup was a geared open station and a cab and now it's a 50+ HP HST CUT and an 80+ hydraulic shuttle-shift.
Set of Heavy Duty Steel Trailer Ramps, 60" Long (A59076)
Set of Heavy Duty...
2012 John Deere 624K (A55272)
2012 John Deere...
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
Toyota LPG 7FGCU20 3,400 Lb. Forklift, S/N 86163, Dual Mast, Tilt, 19,871 Hours Indicated, Asset#... (A59076)
Toyota LPG 7FGCU20...
2014 BRENNER CRUDE TRAILER (A58214)
2014 BRENNER CRUDE...
2019 Deere 35G (A53317)
2019 Deere 35G...
