simple trig help needed
   / simple trig help needed #11
Unless I misread the post, tangent is not the correct function, but cosine is. I believe the correct formula is Cosine of 52=B/C This makes the cosine of 52=100/C which come out to 162.42
   / simple trig help needed #12
He doesnt want to know the hypotenuse he wants to know the other square leg. so tan =opp/adj would be the correct do it all in one whack function I believe.
James K0UA
   / simple trig help needed #13
as I stated before if the actual dimensions are posted I will give him a drawing of the exact distance, he can even give me the difference between the height of one bank to another does not matter. I can even produce a 3d picture if that is what it takes. THIS IS FUN:laughing:
   / simple trig help needed #14
lockhaven said:
use the Pythagorean formula A2 + B2 =C2
so the formula you want is A squared = C squared - B squared you only need 2 parts of a right triangle to solve....
FYI - Pythagorean theorem only works with right triangles.
Mike.
   / simple trig help needed #15
Ok, I see what he is doing, Pick a spot on this side of a stream. Look directly across at the opposite side at a tree. Tree is the angle point. Now walk 100' downstream and measure the angle to the tree. So, you will need The Tangent function. Tan (angle) = 100/(X)
Tan(angle)(X)= 100
X= 100/Tan(angle)
   / simple trig help needed #16
Just curious, how does one compute the 52 degree angle out in the field? A big protractor or something?
   / simple trig help needed #17
I would think a transit would be just the ticket, of course I guess you could build a big protractor.. another great way to find the distance accros that stream would be a nice lazer range finder:thumbsup:
James K0UA
   / simple trig help needed #18
A very inexpensive yet practical way to measure your creek: drill a hole in a baseball, insert a suitable length of non stretch cordage (will suggest a mason line for this...it will stretch, but not before it pulls the ball); tie a keeper knot into the ball thru a metal washer to keep from losing the ball.
Hold onto the very end of the cordage (might even tie a washer / knot on this end to keep from slipping through your grasp) lightly coil the rope in your non throwing hand, then toss the ball across the creek.
Pull ball slowly back to where you desire your starting measurement to be, and if you are standing where you want the ending measurement, slightly taut the line and mark with a piece of tape.
Pull the ball back across, stretch out your line, and the measure the cordage from the ball to your tape, and you have a decent measurement. Probably within a few inches of of the exact.
I happen to have a transit and a laser measuring device that would be the preferred method.
   / simple trig help needed #19
This is that old indian phrase: soh cah toa
Sin=opposite/hypotenuse
Cos=adjavent/hypotenuse
Tan=opposite/adjacent
Probably not PC but that has always been how I remember it.
Kevin
   / simple trig help needed #20
try an old boy scout method... walk away from the point you're trying to cross. get a stick, sight along it from one crossing point to the other. Then, holding the sight point rotate it 180 degrees to the same side and mark the new point. Get a tape measure and measure the distances between the two sight points on your side of the creek. That's how long of a log you'll need to fell to span the creek. Easy and simple.
you can also use this meathod to pick the standing tree you'll need. :laughing:
2014 Chrysler Town & Country Touring-L Wagon (A50860)
2014 Chrysler Town...
John Deere 5310 65HP 4WD Agricultural Utility Tractor (A49346)
John Deere 5310...
2014 Ford Taurus Sedan (A48082)
2014 Ford Taurus...
New/Unused Quick Attach Pallet Forks (A48837)
New/Unused Quick...
2025 Swict 66in Bucket Skid Steer Attachment (A49346)
2025 Swict 66in...
2004 Toyota Camry Sedan (A48082)
2004 Toyota Camry...
