Single acting cylinder help
/ Single acting cylinder help #21
Just about all FEL valves come with load check. They simply keep the cylinders from dumping fluid, when you are shifting the spools. On a FEL valve with float, you should be able to raise the cylinder, and when you want to retract, go to the float position and that opens both cylinder ports to the return path. You can test this by connecting a hose to the return port, and put the other end in a clean bucket, and play with the FEL levers on a double action cyl, or a single action cyl to see what the results are.
2015 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A64556)
2015 Peterbilt 579...
2013 Ford F-150 Pickup Truck (A64194)
2013 Ford F-150...
1998 INTERNATIONAL 2674 6X4 T/A VACUUM TRUCK (A66091)
1998 INTERNATIONAL...
NEW HOLLAND TS115A TRACTOR (A63276)
NEW HOLLAND TS115A...
2006 BOBCAT 5600 TOOLCAT UTILITY WORK MACHINE (A63276)
2006 BOBCAT 5600...
2020 CATERPILLAR 289D3 SKID STEER (A65053)
2020 CATERPILLAR...
