single acting
/ single acting #32
Yes, that is a stacked valve.
You can see the bolts connecting the spool sections together.
/ single acting
contacted two companies now for a quote on stacked valves with 2 DA valves and one SA with carry over (PB) port and 1/2" ports and one is going to post me a quote and i will phone one on monday when their specialist valves guy is back
Cheers Ed
/ single acting
is there really an advantage if getting a slice or stacked valve with 3 double acting ports and plugging one outlet and just getting a normal mono block 3 valve block and plugging one outlet?
basically is there any advantage of getting a stack valve over a monobody valve if they have the same specs and you are doing the same thing with them?
just getting a monobody would be a fair bit cheaper
and for a 3 point mounted forklift of a reasonable size, what would determine if i need 3/4" ports or 1/2" and how many l/minute flow rate i need?
Cheers Ed
2015 ISUZU NQR 4X2 DEBRIS TRUCK (A59908)
2015 ISUZU NQR 4X2...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
Hach AquaTrend APA 6000 High Range Hardness Analyzer (A59317)
Hach AquaTrend APA...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
