Keoke
Hi folks, I am trying to decide what size ABS drain line to a new septic tank. The tank will serve 23 fixture units and there will be about 100 feet between tank and house pitched at 1/4" per foot. Read some stuff about sizing this pipe that said I would be better off with the 3 inch pipe. The reason given for the 3' pipe was that a pipe should be half full of water during a toilet flush to move the solids along in suspension with water. Article says this can be done better with a 3 inch pipe then with a 4 inch pipe. Article also said that a 4 inch pipe was more likely to plug up due to the fact the solids are more likely to fall out water stream and dry cake in the pipe. In short the 4 inch pipe can not meet the half full rule on a toilet flush. This is especially true on a low flush toilet.
I very much like to get the boards opinion (3 or 4 inch pipe) on the above comments.
thanks again folks,
george
thanks again folks,
george
